Best Method For Wallpaper Removal And Re Finishing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 09:25 AM   #1
I love fishing & building
Best method for Wallpaper Removal and Re Finishing
I am removing wallpaper this weekend and the my plan is to use wallpaper primer over adhesive. Then skim coat and prime the spackel with drywall primer then paint. Is this correct? Will this work or could I spackle directly onto the adhesive residue? Then use wallpaper primer?
Sharkbite is offline   Reply With Quote
Old 07-30-2011, 09:31 AM   #2
Civil Engineer
Rewards Points: 4,530
I don't understand. You are removing wallpaper? Why are you using primer over adhesive to remove paper? When I removed my wallpaper, I used wallpaper remover that I got from a Big Box store, mixes in water, spread it on, removes the wallpaper and most of the adhesive came off with the paper. Then I can prep the wallboard normally.
Old 07-30-2011, 12:03 PM   #3
Rewards Points: 5,336
You take off the paper and clean the walls. The adhesive is water soluble. There's no reason to let it stay on the walls.
I do not know what a, "wallpaper primer" is? They sell a primer with a sizing agent in it if you're applying wallpaper on the wall again, but you don't use it for a painted wall.
Ron
B. Franklin 1759
Removal of underlayment under toe space eyeglass Flooring 10 08-26-2009 05:59 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
Which bonding method proper??? Nestor Electrical 2 09-15-2006 07:18 AM
Finishing nail removal bklauer Carpentry 6 09-05-2006 08:13 AM
