Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-09-2013, 10:05 AM   #31
A Little Of Everything
best EASY anti-theft device for home front door
Originally Posted by tuffluck View Post
oh, well i meant putting something up at night while i sleep, specifically. again, i know it may seem unreasonable, but if anyone has access to my key that i don't know, i assume there is always a possibility they can come into my home unwanted. i was just looking for a cheap and easy way to keep them out even if they had a key. obviously during a showing i have to allow them access to my home.
Basically, you're looking for a little peace of mind. Very understandable.
I'd recommend getting some of these cheap magnetic door/window alarms. They won't keep anybody out, but they make one heckuva lot of annoying noise if a door or window is opened.
http://www.walmart.com/ip/19236072?w...l5=pla&veh=sem
Beyond that, if you're really terrified, get a gun.
DrHicks is offline   Reply With Quote
Old 03-10-2013, 09:30 AM   #32
creeper's Avatar
or
you strategically lay out your fishing line trip wire attached to some homemade grenade you’ve concocted and set the device to trip when an intruder comes through your front door Just joking don't do that. It would be morally wrong
creeper is online now   Reply With Quote
Old 03-10-2013, 09:50 AM   #33
creeper's Avatar
Or you could leave music playing all night so the bad Realtor knows you are still awake.
Try this song
http://www.youtube.com/watch?v=1bt-FHaFVH8y
Old 03-10-2013, 12:04 PM   #34
Girl with a Hammer
Have you tought about just taking the key out of the lockbox at night when you sleep and putting it back in the morning so the realtor can use it?
dixongal is offline   Reply With Quote
Old 03-10-2013, 12:10 PM   #35
creeper's Avatar
That has been suggested 3x already. Thats why we have moved on to grenades
Old 03-10-2013, 12:16 PM   #36
Home Remodeler
Most lock boxes can only be opened by an agent with an electronic key. So that option will not work. It can be set for special showing times, like just during the day. Or just put some clothes on before coming out of the shower.
mikey48 is offline   Reply With Quote
Old 03-10-2013, 12:17 PM   #37
creeper's Avatar
Thats just wrong
Old 03-10-2013, 12:27 PM   #38
JOATMON
ddawg16's Avatar
Where do you live that you worry that much about someone coming in at night? The only way a 'rouge' Realtor is going to come in is if they think your not home....make it obvious that your home....problem solved....if they do make it past the door, the handgrenade should take care of the problem.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
creeper (03-10-2013)
Front load Amana washer leaking from inside of door! Stephenby Appliances 4 06-10-2012 07:38 PM
Installing new front door...... Any tips ????? ogoz23 Remodeling 32 05-13-2012 11:10 PM
Front door lock gets stuck injvstice Windows and Doors 13 03-22-2012 01:31 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
New prehung front door not right lofar Carpentry 10 06-18-2009 03:00 PM
