The Best Cleaner For This Kitchen Counter? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-19-2007, 02:39 PM   #1
The best cleaner for this kitchen counter?
Hi,
The counters in our kitchen are made out of granite like material (I believe) that seems to stain easily. When water is spilled on the surface it turns dark brown for about 10 minutes then lightens back up to its original color. However, when some things (like olive oil in the pic below) are spilled they leave a mark. Do you know of a good cleaner to use on this? Thanks a lot.
jojoma is offline   Reply With Quote
Old 08-19-2007, 06:43 PM   #2
Builder/Remodeler
ChrWright's Avatar
Natural and synthetic stones require periodic sealing. If you notice water penetrating deep then it's probably time to reseal. Use a pentrating stone sealer and follow the directions on whoever's product you use.
The first step will be to clean your counters with a stone cleaner. If you have stubborn stains, use a pultice cleaner. Usually these come in a small plastic jar and require you to apply it, cover it with plastic and let it sit for 24-48 hours. The pultice will draw the stain out of the stone.
ChrWright is offline   Reply With Quote
Pass-thru counter gshock Carpentry 6 07-28-2007 11:44 PM
Kitchen Counter Back-Splash satchmo Remodeling 9 06-25-2007 09:33 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
Kitchen Counter Top MichSnoBird2 General DIY Discussions 3 02-07-2006 04:22 PM
