Best Caulk For Metal Windows And Brick Walls - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 06:27 PM   #1
learning to do it right
Send a message via Skype™ to Ginette
Best caulk for metal windows and brick walls
What is the best caulk to use to fill a gap between a black metal window frame and brick walls? The space is 1/4 " on each side.
Would silicone caulk do? Does it dry to a shiny or mat color?
There were two layers of caulking put in by the previous owner (brown mat caulk and clear silicone put over it in a very shabby way) and it was cracked and very poorly done. I removed all the previous caulking with a scraper and will buy caulk remover to finish it off nicely.
Question 2: How free of previous caulk should it be? It is difficult to get caulk out of brick?
Ginette
Ginette is offline   Reply With Quote
Old 09-07-2010, 01:40 AM   #2
Rewards Points: 526
The best caulk I have ever used in manufactured by a Quebec company - Mulco Supra Expert.
http://www.mulco.ca/en/industriel/pr...uits_c_ext.htm
It cannot be tooled so there is a learning curve for the application, but I would think it to be ideal between metal and masonry because it remains so elastic.
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
Ginette (09-08-2010)
Old 09-07-2010, 08:43 AM   #3
Rewards Points: 558
Before you buy any caulking, read the label; some types won’t work in cracks or joints less than ¼’’ wide; others work well only in narrow cracks. Take note of any precautions and follow the directions when you’re using the product.
Now before you can apply new caulking, you’ll have to re-move the old caulking. First, dig out or chip off all of the old caulking with a putty knife, old screw-driver, or scraper. Then brush the area with a wire brush to remove debris and wipe the surface with a cloth soaked in the appropriate solvent for the type of caulking you’re removing. Before applying the new caulking, check the label to see if you need to prime the surface and plan to caulk on a warm, dry day when the temperature is between 50 degrees F and 70 degrees F In hotter weather refrigerate the caulking for an hour or two before use so the caulking won’t run.
The caulks that I would suggest to look at would be:
1) Polyurethane caulk. This type of caulk is best for almost any application, but it can be difficult to use and requires mineral spirits to clean up. It can also be painted if required.
2) Elastomeric caulk. This type of caulk is an excellent choice for most porous surfaces because of its flexibility and adhesion properties, its ease of use and water clean up.
3) Siliconized Acrylic caulk. The most popular caulk and easiest to use, this is a good choice for most applications.
Within each category of the above caulk, look for one with a 50 year warranty. It’s worthwhile to pay a little more for a better grade of caulk.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Old 09-07-2010, 08:59 AM   #4
Rewards Points: 79
NP1 by BASF -- Sonolastic - caulking sealant - that's your answer. It is used by several professional window companies to set windows. Wear a disposable glove when using.
As far as removing caulk on brick or anything else for that matter, CAREFULLY use a heat gun capable of 600 to 1000 degrees. Wagner made, and probably still does, a relatively inexpensive one for stripping paint primarily. Works very well on rock-hard old caulks though. Main thing is - protect the wood if you're ever working around it. I darn near started a fire back in 79 on my house while doing some work on a window. I know you're working near brick, but depending on when it was done, there might be some wood shimming so be careful.
jackofmany is offline   Reply With Quote
The Following User Says Thank You to jackofmany For This Useful Post:
Old 09-07-2010, 11:35 AM   #5
Rewards Points: 582
Burnt sand mastic works well, although it is mainly used between timber windows and masonry.
http://www.masonsmortar.co.uk/site/b...and-mastic.htm
stuart45 is offline   Reply With Quote
Old 09-08-2010, 05:29 PM   #6
So the message is there are multiple options. I do want to stick to something that will last long and is still easy enough to apply by me - aka not too experienced.
Thanks!
g.
Vinyl windows and brick molding a7ecorsair Building & Construction 4 08-10-2010 08:54 PM
Putting windows in an existing brick wall jbaker1516 Remodeling 1 08-07-2009 06:22 AM
Interior insulation of an old brick house 29er Remodeling 3 03-10-2009 06:08 PM
anchoring door in a brick and concrete wall agroux Carpentry 1 05-08-2008 12:28 AM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 08:13 PM
