Bent Soffit - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 05:17 PM   #16
Tom Struble's Avatar
Rewards Points: 2,002
Tom Struble is offline   Reply With Quote
Old 04-22-2012, 08:55 PM   #17
firehawkmph's Avatar
Rewards Points: 1,822
Carefully unbend the lip at the outside edge of the soffit. Pull the few nails that are holding it in and take out the couple of pieces and see what's causing it to buckle. If its vinyl, it should straighten out. There should be a piece of channel above the window that the soffit slides into. I'm guessing the soffit popped out of the channel when you had the windstorm. Or maybe when the window guys did their work they didn't put a piece of channel back in above the window. At any rate, glue is not going to do it. Take it apart and find the problem. Should be a simple repair at that point.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Tom Struble (04-22-2012)
New siding up to existing soffit jtchavez Building & Construction 18 03-25-2012 10:48 AM
Replacing soffit tucked behind brick veneer. Queequeg152 Building & Construction 3 02-25-2012 08:10 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
