Bearing Identification - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 01:11 PM   #1
I am in need of about four flat idler pulleys. They are no longer available and I have searched extensivly! All have bad bearings that are sandwiched between the pulley halves. I removed the rivets and found the ball bearings have no identification numbers.
They are 1.575" OD by .500" thk. and the ID is 3/8" that a 3/8 bolt passes through.
What do you call a bearing like this that doesn't have a precision ID?
Giles is offline   Reply With Quote
Old 11-18-2010, 01:17 PM   #2
Rewards Points: 150
Do you have a "motion industries" local to you? I use them for work all the time. Just take the bearing in, they measure it with calipers and find me a substitute. www.motionindustries.com
240sx4u is offline   Reply With Quote
Old 11-18-2010, 05:59 PM   #3
joed's Avatar
Rewards Points: 13,722
Sounds like a very common bearing. Should not be a problem to find.
Try this catalogue. It will help you figure out which type of bearing and then which actual bearing you need.
http://www.ntn.ca/products.htm
Seems most bearings are metric sized. Are you certain there are no numbers on the side of the race or the seal?
Old 11-18-2010, 08:17 PM   #4
I have worked with many different type bearings, these are the only ones that don't have a number anywhere. The inner race is 3/8" and is not insrted. I checked with a magnifying glass and strong light. I think some changes must be made in order to use other flat pulleys.
Old 11-18-2010, 08:54 PM   #5
Rewards Points: 2,648
Metric OD and inch ID, does not sound like I standard bearing to me. My guess is that the idler pulley manufacturer had those made up special for him. Is the width of the bearing 1/2" or 12mm ? A 6203-2Z ( 40mm OD by 17mm ID x 12mm wide will be readily available, but you would have to bush the ID
SPS-1 is offline   Reply With Quote
Old 11-19-2010, 10:26 AM   #6
joed's Avatar
I think I'd just use a larger bolt instead of a bushing.
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Supporting floor joists on non-load bearing wall? ct9359 Building & Construction 4 07-17-2009 12:59 PM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 11:33 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
