Bearing Block - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 03:15 PM   #1
bearing block
Hey. What can i build whit a ball bearing block?
simon128 is offline   Reply With Quote
Old 12-29-2013, 04:45 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
What is a "ball bearing block" in the area you are living in (wherever it is)?
concretemasonry is offline   Reply With Quote
Old 12-29-2013, 06:15 PM   #3
Rewards Points: 3,130
If you're referring to a pillow block, not much other than what they're designed for, or a door stop. Unless, of couse, your post is some sort of joke.
Old 12-30-2013, 07:47 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
With some rope you can make a boat anchor depending on the size of the block.
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
Rebuilding a cinder block wall Pawl Building & Construction 5 10-09-2011 10:46 PM
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 11:47 PM
Removing bearing wall and putting up a beam Sardinia Building & Construction 2 02-21-2011 07:11 AM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 09:34 PM
