Beams In Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-14-2007, 06:45 AM   #1
beams in basement
my basement beam that supports the floor joists is moving right thruogh the walls in the house how can this be?
kwheaton is offline   Reply With Quote
Old 02-14-2007, 06:53 AM   #2
any body
Old 02-14-2007, 06:56 AM   #3
Rewards Points: 150
What do you mean it is moving through the walls? Do you mean that it starting to bust through an outer wall or something? This forum does not move as fast as I would like either, so I wouldn't expect many other response until at least a few hours have passed....
harleysilo is offline   Reply With Quote
Old 02-14-2007, 07:17 AM   #4
Rewards Points: 150
Details?
Old 02-14-2007, 08:33 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
... ...I am confused as well. Please, can you be more descriptive?
- Build Well -
Old 02-15-2007, 06:27 AM   #6
the main beam in the basement is actually moving through the concrete wall and the walls that were built around it the posts that support the beam are bending also what can make this huge beam move?
Old 02-15-2007, 06:34 AM   #7
the main beam that is installed when the house was built its like the whole house is moving from one side to the other its really apparent when you see the walls that were built in the basement the base ment was finished off the walls that were built around it are also moving ans cracking is causing a lot of damage in the basement i dont know how else to explain it
Old 02-15-2007, 07:06 AM   #8
concretemasonry's Avatar
Rewards Points: 2,594
If you have beams and/or walls moving, you better call an engineer. - QUICK!!!!
These things do not happen by accident.
concretemasonry is online now   Reply With Quote
Old 02-15-2007, 07:45 AM   #9
Rewards Points: 150
Well it sounds as if your house is falling down, just very slowly. Take some pics for youself, your future lawsuit against the builder, home inspector, previous homeowner, real estate person and don't forget to post them in this thread.
Old 02-15-2007, 07:49 AM   #10
As stated....Get a structural Engineer over there pronto...Also, contact your Home Owner's insurance regarding this...
- Build Well -
Old 02-15-2007, 10:24 AM   #11
Can you post a photo?
redline is offline   Reply With Quote
Old 02-15-2007, 03:54 PM   #12
i will take some pictures and get a structural engineer over to look at it thanks for the advice. how can i post pictures on this chat room?
Old 02-15-2007, 06:10 PM   #13
...beats me...I still haven't found the time to figure that out ........on this site....
- Build Well -
Old 02-15-2007, 06:36 PM   #14
Rewards Points: 150
upload them to a free photo hosting service, like www.photobucket.com.
each photo has a unique URL address, it will look something like this:
http://i20.photobucket.com/albums/b2...blow/house.jpg
just select and copy the link, come back to your post here, and click on the yellow "insert image" button above, the yellow one with the mountain...
elementx440 is offline   Reply With Quote
Old 02-15-2007, 06:51 PM   #15
yup its busting right throught the outside top part of the basement wall its like some one is moving the beam i centimeter a year but now its really bad looks like it taking a long time but its moving
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 08:09 AM
