-   -   Bead board as a ceiling? (http://www.diychatroom.com/f2/bead-board-ceiling-171887/)
willy2763 02-13-2013 11:56 PM
My house is 70+ years old and has 3" wide bead board for the ceiling. Some rooms it's covered with drywall and some have a fiber tile style of material stapled to it. The drywall parts are old and damaged and the tile parts have been water damaged in the past, leaving them warped and unsightly. I was considering just removing the covering and leaving the old board as the ceiling, but that would be a horrible air seal as far as insulation, correct? Should I take it down and reuse it in another application and replace with plywood/drywall? I am thinking in terms of stopping conditioned air from leaving through the ceiling. I plan on air sealing the attic and re-insulating later this year, just wanting opinions on whether to change the ceiling while I'm renovating? The old school board is nice and would look great as a wall covering, but as a ceiling?
BigJim 02-14-2013 01:51 AM
T&G beaded ceiling looks great in the older homes. If you are wanting to tighten up your house why not insulate and leave the T&G in place, if it is in good shape, I sure would. T&G should be pretty good against air infiltration, if there are places that are iffy, just caulk and paint.
willy2763 02-14-2013 01:55 AM
I do like it, just had a concern about letting air through. If it holds air then I would be more than happy to keep it. It is painted so maybe that would add to the air tightness? I'll take the covering off and see what it looks like.
