BBQ Grill Platform Idea Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 11:36 AM   #1
Rewards Points: 24
Hey All,
I've got a screened in porch on the back of my house that's about 2' off the ground. To the right of the porch, I've got a patio that is ground level. I was thinking it may be kind of neat to have a sliding screen door on the right of the porch, and have a platform outside the opening that will raise and lower a gas grill from the patio to the porch, and swivel around so we can use it if we're entertaining on the patio, or use it and stay dry if we want to BBQ under the porch. Any suggestions on how to make this? What would I use for the lift? Any kits or anything that could be easily altered/converted for this kind of purpose? Any suggestions or creative ideas would be awesome. Thanks!
Mabrins is offline   Reply With Quote
Old 03-13-2013, 11:50 AM   #2
Originally Posted by Mabrins View Post
Hey All,
Cheaper to buy a second BBQ.
64pvolvo1800 is offline   Reply With Quote
Old 03-13-2013, 12:01 PM   #3
Special User
Rewards Points: 1,230
Need some DOM steel tubing for the vertical shaft, with a flange welded on at the bottom that can be bolted to the concrete patio. Then use the table and clamp mechanism from a drill press to hold the grill on the tubing.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 03-13-2013, 01:27 PM   #4
Rewards Points: 24
Awesome! So how will the grill raise and lower?
Old 03-13-2013, 01:30 PM   #5
Special User
If you use the clamp and table from a floor standing drill press, there should be a toothed rack so you can crank it up and down.
Old 03-13-2013, 01:46 PM   #6
Rewards Points: 24
Thanks for the idea! That could work. Any other suggestions?
Building a platform for washer/dryer syogod Carpentry 10 01-15-2014 10:36 PM
Help with Nat. Gas Line for Grill albertgarrido Plumbing 7 06-29-2010 02:57 PM
DIY exhaust hood for grill sidewayzisbest Appliances 1 09-30-2009 08:51 PM
Painting A/C Fan Grill fritzycat1 Painting 3 09-09-2009 05:50 PM
Husband burned vinyl siding with grill, now what? lanie Building & Construction 18 09-01-2005 11:30 AM
