-   -   BBQ Grill Platform Idea Help (http://www.diychatroom.com/f2/bbq-grill-platform-idea-help-174387/)
Mabrins 03-13-2013 11:36 AM
Hey All,
I've got a screened in porch on the back of my house that's about 2' off the ground. To the right of the porch, I've got a patio that is ground level. I was thinking it may be kind of neat to have a sliding screen door on the right of the porch, and have a platform outside the opening that will raise and lower a gas grill from the patio to the porch, and swivel around so we can use it if we're entertaining on the patio, or use it and stay dry if we want to BBQ under the porch. Any suggestions on how to make this? What would I use for the lift? Any kits or anything that could be easily altered/converted for this kind of purpose? Any suggestions or creative ideas would be awesome. Thanks!
64pvolvo1800 03-13-2013 11:50 AM
Originally Posted by Mabrins (Post 1136275)
Hey All,
Cheaper to buy a second BBQ.
tylernt 03-13-2013 12:01 PM
Need some DOM steel tubing for the vertical shaft, with a flange welded on at the bottom that can be bolted to the concrete patio. Then use the table and clamp mechanism from a drill press to hold the grill on the tubing.
Mabrins 03-13-2013 01:27 PM
Awesome! So how will the grill raise and lower?
tylernt 03-13-2013 01:30 PM
If you use the clamp and table from a floor standing drill press, there should be a toothed rack so you can crank it up and down.
Mabrins 03-13-2013 01:46 PM
Thanks for the idea! That could work. Any other suggestions?
