Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-12-2012, 09:59 AM   #1
bathtub drywall repair
i just had a new bathtub/shower surround put in upstairs and now there is
a 2 inch space between the new surround and the existing drywall, how do
i repair this space. thanks tomtee59
tomtee59 is offline   Reply With Quote
Old 12-12-2012, 10:34 AM   #2
Got a picture?
Is it a nail on or a glued up enclosure?
tomtee59 (12-12-2012)
Old 12-12-2012, 10:35 AM   #3
Is this something you installed? If not, why didn't the installer finish it. Can you post a picture so we can at least see what you are up against. My first inclination is to say fill the gap with drywall strips and tape & mud to suit.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 12-12-2012, 10:41 AM   #4
If this is a nail one and the 2" is where the lip of the enclosure is, the problum is from you not just removing all the drywall and only cutting it back just enought to fit it in.
The flange around the unit sticks out away from the wall so if you do as the other poster suggested the patch would be tipped and to flimsy to tape and mud.
I use lattis to shim out the studs just enough so the drywall lays flat.
Old 12-15-2012, 09:24 PM   #5
So how can you fill this space without re-drywalling the entire room?
Total Tool is offline   Reply With Quote
drywall repair raspy Drywall & Plaster 6 07-30-2012 09:58 PM
Repair Outside Corner Drywall in Bath mollylibby Drywall & Plaster 5 07-01-2012 10:51 AM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 11:07 AM
Best way to repair poor drywall installation? RyanD Drywall & Plaster 5 05-19-2009 09:13 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
