Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-11-2009, 09:28 AM   #1
Bathroom ventilation and cooling
I have a full bath off of the master bedroom that is on the east side of the house. It has an HVAC vent, but vent to remove moisture. There is a small window as well. The problem is the room gets too hot in the mornings and the better half says she can not do her hair and what not.
The two ideas I have are to add a vent and fan for the humidity and change the lighting to some bulbs that put out less heat. Are there any other ideas on ways to keep the room cooler?
We keep the AC running pretty cool thru the night, that room just seems to warm up quickly.
dragon6172 is offline   Reply With Quote
Old 05-11-2009, 10:13 AM   #2
Moderator
Termite's Avatar
A high quality bath fan that moves plenty of CFM's could be installed in the ceiling or wall and vented to the outdoors. A good fan will suck the heat out of a small room like that in no time.
Old 05-11-2009, 10:58 AM   #3
Thanks. I figured the lack of a fan was the main culprit. The two bathrooms share a wall so my plan was to install a vent and join it with the main bathrooms vent through the roof. I have found some DIY examples on how to do this with an inline fan between the Y and the roof vent. This seems easier for me than cutting through my wall and installing a seperate fan for the master bath. We typically keep both bathroom doors closed so I would imagine the right fan would create enough suction for both bathrooms.
Old 05-11-2009, 03:40 PM   #4
Household Handyman
I'm not sure whether you are adding an exhaust vent fan to your bath or an additional HVAC vent/register to move more air. IF you are adding an exhaust vent fan or upgrading your existing exhaust vent fan may I highly suggest looking into replacing your switch for the exhaust fan or combo light/fan with a timed switch. I have learned that leaving our bath when I "thought" I was finished only left moisture in the air which actually leaves the bath area hotter than I would like it. I put a timed switch on our fan(s) in both baths and now we just turn the switch to the OFF position and the timer turns the fan OFF after twenty minutes. The bath(s) are always cooler now.
Attic Ventilation stouto Roofing/Siding 3 11-11-2008 04:04 PM
