Bathroom Vanity Against A Pre-existing Wall Of Tile - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 08:01 AM   #1
Bathroom Vanity against a pre-existing wall of tile
Hi there..
I just bought a new home and want to a simple update to the guest bathroom vanity. It’s coming loose so it shouldn’t be difficult to pull it off. Here’s the thing….the wall it is attached to is tile. Before I get crazy and start ripping this thing off….how am I going to reinstall a new vanity to a wall of tile? This sounds a contractor’s job, correct? If there were studs I could pretty much handle it myself but now I’m not so sure.
Dave
dcormann is offline   Reply With Quote
Old 03-24-2009, 08:23 AM   #2
You should find studs behind the tile and whatever backer board was used. You may find that the current vanity is attached to these same studs.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-24-2009, 01:05 PM   #3
Rewards Points: 5,336
This vanity should be screwed to the wall. Open the doors and look at the rail near the top of the vanity on the back. Don't just yank the vanity off the wall. You'll attach the new vanity the same way. You drill through the tile and insert a plastic molly on each end. You insert the screws through the back rail, into the mollies and screw them snug to the wall. You might be able to use the old mollies if you can drill holes in the new vanity that match the molly configuration. To do that place one nail in each hole, point out. Position the vanity where you want it and slide it back so the nails leave a mark on the rail. Pull the vanity out and drill an over size hole to give you some leeway. Insert a screw with a washer through the hole and push the vanity back enough so you can get the screws into the mollies. Start the screws and then finish pushing the vanity to the wall. Tighten the screws so they're snug.
Ron
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 06:18 PM
Patch a hole in the bathroom tile sw41 Flooring 1 12-07-2008 12:57 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
