Bathroom Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-12-2007, 10:15 AM   #1
Bathroom Problem
I recently smelled mildew in my bathroom. After removing drywall I found the mold and that the insulation was wet. The were no apparent leaks in the exposed plumbing or drains. The exterior walls are stucco with a limestone rock base. The area between the exterior rock and interior particle board appears to be retaining moister and some of the particle board was dry rotted. Any suggestions to eliminate the moisture coming in before closing the walls?
1-homeimprovement is offline   Reply With Quote
Old 09-12-2007, 10:29 AM   #2
Not to sound so obvious, but how about just getting a really powerful good dehumidifier.
polar5554 is offline   Reply With Quote
Old 09-12-2007, 11:40 AM   #3
Do you really mean particleboard? Is it hung on the walls?
Is the insulation inside the wall wet to the top? If so, I'd guess your leak is from above.
If this is in a tub-surround, and the moisture is lower, perhaps it's getting wicked up behind the tiles, at the tub rim?
NateHanson is offline   Reply With Quote
Old 09-13-2007, 06:59 AM   #4
Rewards Points: 528
http://www.buildingscience.com/resou...r_Barriers.pdf
That article may help you.
<Any suggestions to eliminate the moisture coming in before closing the
walls>
You have to make sure the wetness is not coming in from around the tub, where it meets the wall. Joints that need caulking?
Can you post a picture?
The wall facing the exterior may need a vapor barrier or if it had one, it may not have been installed properly.
Do you have a exhaust fan for the bathroom?
rjordan392 is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
bathroom vent fan - condensation problem jaspar General DIY Discussions 16 03-23-2012 11:54 AM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Bathroom paint problem ERIK2173 Painting 3 05-22-2006 11:22 PM
