Is it code that bathroom exhaust fans be vented outdoors? I live in East TN and I hardly ever see this done. Practically none of the houses in my subdivision have any vents from exhaust fans on their roof. I live in a split-foyer home (built in 2001) that has 2 bathrooms upstairs and 1 bathroom in the basement. None of these fans vent outside. They don't even have ductwork connected to them.
Choose one;
unqualified for their position, don't care, retiring soon, don't know, it was Friday, forgot to write it, forgot their pen/pencil, was talking on the phone while inspecting, thinking of something/someone else, was upset with their boss/day, had to use the restroom soon, or I don't know!
As far as I know, a bathroom exhaust fan must be vented outside. Though a roof vent isn't necessary. You can vent through the wall and use a dryer vent on the exterior, or vent through the soffit (like mine is).
M1507.2 Recirculation of air. Exhaust air from bathrooms and toilet rooms shall not be recirculated within a residence or to another dwelling unit and shall be exhausted directly to the outdoors. Exhaust air from bathrooms and toilet rooms shall not discharge into an attic, crawl space or other areas inside the building. http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_15_sec007_par001.htm
I disagree with that suprvee. Venting through the soffit allows the moist air drawn from the bathroom to be drawn back up through the soffit and into the attic, an unconditioned space, that in time will develop mold problems. The only way to vent a bathroom properly is through the roof.
GBR, I read this as "if you vent the bathroom, it must be to the outdoor". Further north, houses are tight (at least they are supposed to be), and I need a second switch on my main floor, so I can turn on my bathroom fan for house ventilation. But in TN, I am not so sure that is the case.
Does this answer your question? R303.3 Bathrooms. Bathrooms, water closet compartments and other similar rooms shall be provided with aggregate glazing area in windows of not less than 3 square feet (0.3 m2), one-half of which must be openable.
Exception: The glazed areas shall not be required where artificial light and a mechanical ventilation system are provided. The minimum ventilation rates shall be 50 cubic feet per minute (24 L/s) for intermittent ventilation or 20 cubic feet per minute (10 L/s) for continuous ventilation. Ventilation air from the space shall be exhausted directly to the outside. http://publicecodes.citation.com/icod/irc/2009/icod_irc_2009_3_sec003_par002.htm
When I built my cabin the inspector suggested I vent out the wall because ( he said) roof vents don't work well when you have 4 feet of snow on the roof.
Regardless of where you live, if you have vent fans installed with no ductwork whatsoever, the installer was incompetent. What purpose do they serve if they are not cunducting the air to another area, at least to a ventilated attic or crawl space. Where is all that shower steam going when the fan is turned on? You would be better off not turning them on at all and opening the window or door instead.
there is a metal flex tube/duct from fan to vent to outside air.the flapper keeps outside air from comming back into house.unless this duct comes off,no exch to attic.
They were talking about a soffit vented bath fan. The moisture laden air is expelled next to the soffit vent which takes that moisture laden air into the attic. The flapper just keeps the cold exterior air from being drawn into the ductwork after the dryer stops. That is if the flappers are cleaned on a regular basis and don't keep the flappers open with caked lint.
The issue is seasonal in the colder climates as convection is limited in the cooler seasons.
Ron
This has been a code change in the last several years. The 2000 IRC permitted you to discharge a bath fan into a ventilated attic. More recent editions require it to discharge to the outdoors. Nothing requires that it go through the roof. Personally I see penetrating the roof as a last resort, and feel that a soffit penetration or a gable penetration is more desirable. The aforementioned soffit penetration/damper kits are really slick, and are very similar to a dryer vent termination. Code doesn't require a metal pipe that I'm aware of, and flexible vents are fine.
Real world, the problems with soffit vents as compared with gable, roof and sidewall vents usually involve installation issues, including:
1) They often involve longer runs that through-roof vents.
2) By their nature, they involve horizontal runs.
3) They are more often run in flexible ducts.
4) These three conditions mean that they are usually much more subject to low spots and other causes of condensation problems.
5) Because they are on the attic floor, and usually in flexible duct, they are considerably more likely to experience mechanical damage from foot traffic and stored household goods:
6) Especially at roofs with a slope lower than 4/12, it is often somewhere between difficult and impossible to correctly install the duct and terminations, during my inspections this is a very common location at which to find disconnected or damaged ducting:
The bottom line is that assuming a properly pitched vent is run in properly insulated hard pipe and correctly and permanently connected to a properly installed termination, and as long as the attic is not negatively pressurized (for example by a powered attic ventilation fan) and exhaust air is not drawn back in through the soffit vents, then a soffit vent is fine - but at least in my area (Chicago) the chances of finding such an installation are pretty slim.
Those pictures are clearly excessive, some aren't even of the description that is printed on it. For example, the excessive bends and twists in the first picture is not what flexible duct is "prone to do", that was installed in a poorly way. That is VERY easy to fix and make right.
In the second picture, it's not foot traffic or stored material that did that to the duct, it's the person who installed the high hat, he specifically separated the duct to install the light where it looked correct from down below, the duct now needs to be reconnected or rerouted.
In the third picture, the good money says that the installer just ran the duct to the soffit, they didn't cut the soffit out and install a proper soffit vent.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
