Bathroom Exhaust Fan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 09:26 PM   #1
Rewards Points: 131
Bathroom exhaust fan
I want to add a bathroom exhaust fan. The ceilng in the bathroom is vaulted with only 6 inches of room between ceiling and roof deck. I have read that there are ceiling fans and wall fans. Which would be my best option?
wwkayaker is offline   Reply With Quote
Old 09-02-2012, 10:25 AM   #2
Rewards Points: 3,130
I would use a wall fan. They aren't as easy to find but do exist.
Old 09-02-2012, 04:26 PM   #3
Rewards Points: 131
Thanks for the response. After a fair bit of searching, I found a couple of wall fans that should do the trick. Next, fishing wire through the wall/ceiling.
Old 09-02-2012, 07:24 PM   #4
Bombastic Idiot
notmrjohn's Avatar
Doncha just love slab foundations? And no other electrical on the vent wall, huh?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-02-2012, 11:26 PM   #5
In a little over my head
Rewards Points: 706
Aura Vents has a bath fan that mounts the fan above the roof. Mine works great. Check with them and see if it will work for you.
http://roofvents.com/
ratherbefishing is offline   Reply With Quote
Old 09-03-2012, 12:04 AM   #6
Bombastic Idiot
notmrjohn's Avatar
ratherbefishing (me too) you sure you want that passive ventilation? 24 hours a day suckin AC air out? Might not be so bad in bath and it is up in hot room top air. I need similar thing for different app, this looks good compared to prices I've found. I'm gonna look for a powered damper.
Can I put my bathroom exhaust fan outlet where I want to? danielrg HVAC 9 04-07-2013 08:44 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 11:36 AM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 11:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 08:41 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
