Bathroom Exhaust Fan - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 03:43 PM   #16
Originally Posted by Doc Holliday View Post
It's legal down here to vent a bathroom exhaust fan into the attic as long as it ends near the soffit. It does not have to penetrate the roof or actually be fitted to the soffit as in the pic.
Here too, its legal. However, just because its legal does not mean its wise to do. Exhaust fans pull moisture and hot air out of the bathroom. If you let that circulate around in an attic it could possibly create a condition for mold growth.
jasin is offline   Reply With Quote
Old 02-16-2012, 06:53 PM   #17
Not a Noob or Boob
Originally Posted by Rob1975 View Post
I would recommend a roof vent that is designed for exhausts as it will have a baffle as well as the baffle in the fan.
Originally Posted by jasin View Post
It should be exhausted to the outside separate from any other vents. Out through the soffit is satisfactory, but the roof is always better as you have more space to put in a bigger vent, correct vent, and do not interrupt what the soffit is designed for. In your picture thats the wrong vent anyways ... if its to be vented through the soffit. That's soffit ventilation.
1st choice: out of a vent designed for exhaust ventilation
2nd choice: out of a roof vent (which is how 90% of fans are vented)
3rd choice: out the gable end of a roof
Can't imagine it going out the soffit. That would direct it down putting a turn that would collect moisture. Maybe I misunderstood.
Rob1975 is offline   Reply With Quote
Old 02-16-2012, 07:02 PM   #18
The setup in that picture I posted is the best way to vent. With exception to the run going horizontally. I would go straight up to the roof not horizontally as is pictured. Going out the soffit is allowed in some places, but I do not suggest going that route.
Old 02-16-2012, 07:18 PM   #19
If it were my house I would keep the Exhaust fan ventilation separate from all other vents as ridge vents, drain waste vents, soffit vents, dryer vents, etc. all have a different function and purpose.
Old 02-16-2012, 08:21 PM   #20
Not a Noob or Boob
We are saying the same thing.
Old 02-16-2012, 09:50 PM   #21
Can I put my bathroom exhaust fan outlet where I want to? danielrg HVAC 9 04-07-2013 07:44 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 10:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
