Bathroom Attic Fan Vented To Attic. Damage? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 03:14 PM   #1
Rewards Points: 105
Bathroom Attic Fan vented to Attic. Damage?
I have a bathroom fan that vents straight up into our tiny attic. The attic is only 3 1/2 feet high at it's highest point down the center, and stuffed with insulation... So viewing inside of it is impossible. The attic has an opening on both the north and south sides, so wind does blow air through.
Two questions:
1) Can there be damage in the attic, as it appears to have been this way for a while? Is there possibly mold (I didnt smell anything up there)?
2) When I cut a whole into the roof to vent (impossible to get to soffit, I can only fit 1/2 way back and the slope is less than 18" for me to crawl more), is there anything I should be aware of?
Thanks!
jdm001 is offline   Reply With Quote
Old 02-19-2011, 06:08 PM   #2
Two questions:
Thanks!
It's really bad to have moisture from your bathroom fan going into your attic. Not only can the moisture soak your insulation reducing it's effectiveness, but it can also cause electrical problems with your wiring if the moisture collects on the inside of the roof and drips down onto any wiring. It's an easy fix to cut a hole into your roof and install a vent. Once you're on your roof you'll have access to your fan and can install your ducting. I did mine and it's an easy afternoon project.
Good Luck
sciron is offline   Reply With Quote
Old 02-19-2011, 06:32 PM   #3
Rewards Points: 6,652
There can, especially if the moisture can not leave the space. If you can get a good roofer to add a roof vent for the attic vent, that would be the best way, or vent out of a sidewall or sofitt.
Old 02-19-2011, 06:59 PM   #4
I can tie my own shoes
algored2deth's Avatar
Two questions:
Thanks!
If you don't see mold or any funny discolorations, I would suspect no damage.
Make sure to vent through the roof and not the soffit. Going through the soffit (provided it is ventilated correctly) can just cause moisture to possibly re-enter your attic.
Use rigid duct/piping. Don't use that accordion hose. Also make sure to seal any joints on the ductwork and use insulation to wrap around it to prevent condensation from running back down into your bathroom. Also make sure that your fan housing box has been caulked/spray foamed so that heated air does not leave your home where it comes through the ceiling.
algored2deth is offline   Reply With Quote
Old 02-20-2011, 11:33 AM   #5
Rewards Points: 105
Thanks everyone, really appreciate the help!
Algored, why not use the corrugated accordion style? I know the ridges make the air flow less efficient, but as long as it vents should I care? Is there another reason?
Not to cut corners, but I literally only have about 2 feet of clearance in the attic, and I'll be doing this on my back... so messing with elbows and joints will me impossible I think.
I *might* be able to if I preassemble and guess at the length, so I can try if there's a big reason to do so. Can you let me know if you think it's necessary for my situation?
Old 02-20-2011, 01:30 PM   #6
The corrugated stuff is just more restrictive. The rigid piping is also easier to insulate. If it is such a short run, then it may not matter that much. Just get the insulated version and you will be fine.
Old 02-21-2011, 10:35 AM   #7
This. I had my kitchen exhaust vented into my attic for about 15 years (one of the previous owners did some cowboy remolding). The only damage was to the insulation, which smelled like bacon. My attic is only 4' high, but has good ventilation.
suprvee is offline   Reply With Quote
Old 02-21-2011, 09:50 PM   #8
I installed a vent fan in our bathroom a couple years ago, and not wanting to go thru a shake shingle roof, I went thru the attic wall and installed one of those things for dryer vents with little shutters. Works good, but you don't always have an attic wall nearby either.
Malibujim is offline   Reply With Quote
Old 03-04-2011, 11:49 AM   #9
Rewards Points: 105
Thanks to everyone who posted help, I need to call on you all again please!
So I went to fix this and I found that the bathroom fan vented into the attic like I had thought, but, when I got up there I was surprised.
It vents directly under one of those weird turbine vents on the roof (I included a pic of a new one for reference), literally three feet directly under it, but no duct hosing or anything.
1) What does that style roof vent do? I can see slight slivers of daylight in it, and there's no ductwork, just a big 8 inch circular hole with that turbine on top.
2) So how do I now vent the bathroom fan. It would look silly having a small vent six inches from the turbine vent.
I can probably make or find a way to shrink the 8 inch opening to go down to a three inch for the bath fan exhaust. Would closing that vent off to the rest of the attic (there's another "turbine vent on the other side of my small ranch house).. would it hurt airflow?
Please help with advice, and again thanks in advance!
Old 03-04-2011, 12:07 PM   #10
Rewards Points: 105
So I did some reading on roof vents, and it appears these are good for my roof to pull air without any electricity! But my question is, can I just install the new bath fan and nail the edge of the duct inside the larger opening for the roof vents.
I know it would partially block about half of the vent for the roof, but it would also directly exhaust out the moist air from the bathroom up into the turbine of the roof sucking it away.
Is this correct, is this the best way to do this ?
Old 03-04-2011, 01:29 PM   #11
Vent to Roof Turbine
That's what I did many years ago. Checked it often since. No sign of trouble.
Did insulate the 6 inch vent pipe. My attic is 9foot high at the ridge. Ken
jankencanada is offline   Reply With Quote
Old 03-04-2011, 01:35 PM   #12
Rewards Points: 5,336
This is not correct or the best way.
Ron
Old 03-04-2011, 01:44 PM   #13
I would say no. I think you are going to have to make a new hole in your roof, put in a correct vent, run a couple elbows with rigid insulated pipe, and vent through that new spot. Not a good idea to vent humid air through a vent not made for it. You have no guarantee that the vent is spinning continuously anyways. Your project has just gotten harder. There is a video or two over at askthebuilder.com that shows how to do the install. Not hard to do.
Old 03-04-2011, 02:12 PM   #14
Rewards Points: 105
Algored: Is there any problem using about 3-4 feet of that flexible stuff, and then making a new hole approximately 2' from the fan (and about 1' from the top of the ridge)? I can move it sideways more, but no matter what i do, there's just not enough room to work with the rigid duct and put in elbows in that tight of space.
Old 03-04-2011, 02:31 PM   #15
Not a big fan of the flex stuff but sometimes you got do what you got to do. If you were going to run 20' of the stuff then that is a different matter. It is when you take long runs of the stuff and let it sag and have areas where debris can collect in little valleys. It reduces flow rate, yadda yadda yadda. There is flexible aluminum out there as well I believe. Check into that because it may work. Not sure on how tight you can make a radius with it though. You will probably be ok. I am sure if others are reading this and think otherwise, they will chime in.
dennis
moisture in attic rocky1charle Roofing/Siding 17 02-02-2010 05:10 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Bathroom floor water damage. makisushi Flooring 2 05-19-2007 01:48 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
