Basic Multimeter Usage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 11:49 AM   #1
Basic multimeter usage
I just purchased the Gardner Bender GDT-3200 multimeter. It came with a black and red probe plus a one probe that has two ends that goes into the two wholes on the unit. I have read some basic usage of a multimeter but still feel like I need more info.
1. What does a single prob that has two ends that goes inside the unit's two holes use for?
2. When the instruction said, "touch the negative probe to a known ground". What is "ground" mean in this case? Is it the ground as dirt/earth?
3. If I want to find the AC voltage on a wire, do I need to touch the negative probe to ground? If not, how do I measure the number of volts that's coming off a wire cable?
Thanks!
2Charlie is offline   Reply With Quote
Old 07-27-2010, 01:15 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
1 It sounds like you are talking about the temperature probe.
2 It means a metallic object or wire that is connected to a grounded electrode - yes that means a metal rod stuck in the ground. Like the bare copper wire in an electrical cable.
3 Touch the probes to the white and black wire in the cable or the silver and gold colored terminals on a receptacle. You can also test from a known ground (see #2) and the black wire in a cable or the gold screw on a receptacle.
Coastal South Carolina
Old 07-27-2010, 01:25 PM   #3
Electrician
Proby's Avatar
2Charlie, what type of work are you looking to do with this meter?
I think it's best if you study up on the basics of electricity, that will help you become much more productive with the meter.
Proby is offline   Reply With Quote
Old 07-27-2010, 03:54 PM   #4
Rewards Points: 5,336
Thanks!
If this unit came with instructions, you should read through them a few times. If it didn't, see if you can pick them up online.
This tool should not be used unless you fully understand what you're doing.
Ron
Old 07-29-2010, 11:52 AM   #5
Rewards Points: 3,130
It sounds like you know little to nothing about electricity. You'd better learn. Checking voltage when your meter is set to resistance or current measurement will blow it up (literally).
Old 07-30-2010, 04:24 PM   #6
If you seach Google or another search engine using 'multimeter usage' you will find many locations with good instructions.
When I searched I found this site ' ' and it gives some idea of what a multimeter can be used for.
A multimeter isn't magical. If you have no idea of what the terms voltage, amperage and resistance mean, a meter will have little value to you.
As has been previously noted, knowledge of basic electricity a must, if you hope to make use of the meter.
For example http://www.educypedia.be/electronics...tycircuits.htm
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 09:55 AM
How to use a multimeter to tell which one is red? dtc HVAC 1 10-13-2009 06:52 AM
multimeter question spikesnet Electrical 3 10-20-2008 11:21 AM
Need Recommendation on Multimeter Revnjeff Electrical 6 10-18-2008 11:04 PM
New to electrical - which tools are my basic needs? joeyboy Electrical 15 08-29-2007 09:24 PM
