Basement Waterproofing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-13-2009, 06:45 PM   #1
We are looking to finish our basement and would like some advice on waterproofing the walls. We have already sealed the cracks in the walls with hydraulic cement, now we are wondering which waterproofing sealant/paint is best. (Behr, Dry-Lok, Zinsser, other commercial powder brands?)
Thanks!
Wendy
johnnydop is offline   Reply With Quote
Old 03-13-2009, 07:51 PM   #2
I used Dry Lok and it seems to work great. I still keep a dehumitifer down there though.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 03-13-2009, 09:52 PM   #3
You might want to consider Thoroseal
www.thoroproducts.com/pdf_appl/appl_damproofing_paint.pdf
Rivethead is offline   Reply With Quote
Old 03-13-2009, 10:16 PM   #4
concretemasonry's Avatar
Rewards Points: 2,594
Thoroseal has been used successfully on commercial, civil and industrial construction for many years before DryLok, etc. were though of.
The beauty of Thoroseal is that is totally compatible with concrete surfaces, bonds to it very well, can/should be applied to a damp/moist surface and can be recoated later by more other materials. - There are other concrete based restoration/maintenance Thoro products that can applied as a finer finishe coat.
It is usually not a "big box" DIY products, but can be obtained in some DIY stores and in contractor suppply outlets. It is messly to apply, but it is unbelievably effective.
Dick
concretemasonry is online now   Reply With Quote
Old 03-14-2009, 11:14 AM   #5
Dick
In your opinio would say that Throseal is that much better then a DryLok or Behr product, both of which come ready to apply?
Old 03-14-2009, 12:11 PM   #6
Yes. When I did my basement, I could have gotten DryLok, but used Thoroseal even though it was more work.
Waterproofing before remodeling in basement? Peterbay Remodeling 8 11-14-2016 07:03 AM
Basement Waterproofing javan Building & Construction 29 08-19-2008 12:58 PM
waterproofing basement flashme18 Painting 12 06-25-2008 03:57 PM
Waterproofing Basement SnowUtopia Building & Construction 20 05-03-2008 09:23 AM
basement waterproofing nlexi912 Building & Construction 6 12-31-2006 11:27 AM
