Basement Water Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 09:44 PM   #1
Rewards Points: 12
Ok so let me give an overview.
I have a sump pump and from what I can gather a floating foundation.
There is a trench around my entire basement about 1 inch deep 2 inches wide.
Problem I am having is the pitch/grade of the drainage trench is low in one point and won't drain into the sump pump...
I cleaned it out made it slightly better. However there is so much sediment in the trench that it has changed the grade or if I am right and we have a floating foundation that is affecting the pitch.
In one corner of the basement the trench is completely filled with sediment and dirt..
Any recommendations on what I cam because right now I have water sitting I the trench around my basement. I will add pictures in a few.
Thanks in advance!!!
Sent from my SM-N900V using Tapatalk
jasonbran16 is offline   Reply With Quote
Old 05-18-2014, 10:47 PM   #2
Rewards Points: 12
Basement Water Problem-uploadfromtaptalk1400471190387.jpgBasement Water Problem-uploadfromtaptalk1400471200567.jpgBasement Water Problem-uploadfromtaptalk1400471210241.jpgBasement Water Problem-uploadfromtaptalk1400471220700.jpg
Old 05-19-2014, 06:05 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by jasonbran16 View Post
I have a sump pump ... There is a trench around my entire basement (with a gap at the top of it near the wall) about 1 inch deep 2 inches wide.
pitch/grade of the drainage trench is low in one point...
Ordinarily there is NO pitch with floor drain trenchs
...there is so much sediment in the trench...
Is there gravel and a pipe below that leading to the sump pit?
Any recommendations on...
Dig deeper into what you have vs what should be.
Perhaps this will mean re-digging the trench to lay in pipe and gravel.
Old 05-19-2014, 08:07 AM   #4
Here's a great solution to your problem. Keep in mind you can also make your own little system to fit your needs, just use your imagination.
http://www.ronhazelton.com/projects/...oof_a_basement
ron45 is offline   Reply With Quote
Old 05-19-2014, 08:17 AM   #5
Rob
Robpo's Avatar
Rewards Points: 826
I would clean out 3-4'' down in the trench.
Robpo is offline   Reply With Quote
Old 05-19-2014, 10:05 AM   #6
Rewards Points: 12
The trench is concrete so once I clean out the sediment it's pain staking chisel work or hiring someone with a jack hammer.
So there is no pipe in the drain.
Old 05-19-2014, 10:13 AM   #7
MarginallyQualified
Ar you sure? Open the sump pump cover and look inside to confirm.
If you really have no pipe in the ground...
then you'll have no choice but to beak up the floor and start over.
The trench is concret(ed over)
once I clean out the sediment (from the gap at the top)...
it's... hiring someone with a jack hammer.
Likely so. It's a fairly common job and even DIYable.
Basement Water Problem-beforesump.jpg   Basement Water Problem-aftersump.jpg   Basement Water Problem-sump-aboutdone.jpg
Old 05-19-2014, 10:51 AM   #8
Rewards Points: 12
Good call I will check inside the sump.... even so why would there be a ridge/trench around the basement
Old 05-19-2014, 12:13 PM   #9
MarginallyQualified
The trench is where the gravel covered perforated 4" pipe goes.
The gap at the top of that concreted over trench is because water can still get in (like through those holes in the block)... so you need to give it a place to go to aside from on your floor.
Related to all this is the exterior work to minimize water coming in... things like grading, foundation plant placement, rain gutters, downspouts etc. all of which should be done right before the step of renting the jackhammer and hiring the local high school football team linemen to do the grunt work for you (hint) on some future Saturday
Old 05-19-2014, 12:17 PM   #10
Rewards Points: 12
Our outside issues are a whole other problem I am working with the county to see if they can assist because something isn't right.... looked in the sump no drain it so the builder was just relying on the trench to drain the water....
Old 05-19-2014, 12:18 PM   #11
Rewards Points: 12
There was a tray sitting the basement with a black hose running through the trench from the tray to the sump but it was always dry and served no put purpose. Ever heard of something like that?
Water Intrusion in Basement dasoul Concrete, Stone & Masonry 10 04-16-2014 08:42 AM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Basement Sump Pump for Roof Water housefixr Plumbing 4 08-26-2012 09:39 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
