Basement Wall Replacent - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-14-2007, 12:48 PM   #1
Basement wall replacent
Hi everyone, one of my basement walls is caving in and it looks really bad. Since I don't have a whole lot of money at the moment I thought may be I could fix it myself to save money. I thought about splitting the wall up into 3 or 4 sections and removing the blocks one section at a time to avoid having to raise up the house. Then move to the next section only after the blocks have been put back. Can anyone tell me if that can be done? Thank you in advance for your suggestions.
ColumbusMan is offline   Reply With Quote
Old 09-14-2007, 01:25 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
Before you go to the effort of replacing the wall you should find out the cause and make sure the same thing does not happen again.
Doing in separate sections will not be as strong as a continuous wall. The wall probably will need some reinforcement.
A professional engineer should be consulted to give you some options for your situation.
concretemasonry is online now   Reply With Quote
Old 09-14-2007, 10:22 PM   #3
Rewards Points: 6,652
You will still need to brace the structure, unless you have done so already. It comes down to the structure being uninhabitable if it is as bad as you are stating it to be. Also, do you not have Homeowner's Insurance? You may be covered.
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 08:35 PM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 04:29 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 09:16 AM
