Basement Wall Project - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 11:46 PM   #16
Rewards Points: 1,418
Two vapor barriers is a no-no.
My house has the same black coating on the outside of the concrete foundation. I assumed (for better or worse) that the coating was a vapor barrier and I put up a typical stud and fiberglass insulation and drywall wall against the foundation with no additional vapor barrier.
The inspector saw the lack of a vapor barrier on the inside and gave it a passing grade.
I just hope that any moisture that got through the drywall and insulation and condensed against or inside the concrete in winter will evaporate in the summer.
Old 01-04-2010, 10:26 AM   #17
ccarlisle's Avatar
But AllanJ, the inspector could have seen the black coating outside, noted that it was a waterproofing membrane, and then saw your drywall on the inside and noted that that was a vapour retarder, so he passed it, no?
What do you assume now about your black stuff?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
raised ranch basement bathroom project teamrudy Carpentry 5 01-07-2010 11:39 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
Finishing old basement force4ormore Building & Construction 1 12-29-2008 03:48 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
