Basement = Vent Or Not - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 08:42 AM   #1
basement = vent or not
Im looking to dry out my basement. First I need to replace the windows. Should I install vents or dry it out and seal it up? I've heard it both ways.
rick32 is offline   Reply With Quote
Old 09-19-2009, 08:44 AM   #2
Install vents? As in venting windows?
Old 09-19-2009, 10:12 AM   #3
Rewards Points: 5,336
You need to know what is causing the dampness. You should also know how damp it is. In most cases you would need an appropriately sized dehumidifier to control excessive dampness.
Energy wise, you should only expect to keep the basement at between 50-60%. You can go lower, but it heats up the basement excessively and you pay more for the heat.
Ron
Old 09-19-2009, 11:03 AM   #4
I did install LOWE venting windows in my basement to replace the single pane windows
Its nice to be able to open them on a dry/nice day & let the basement air out
I run a dehumidifer (I have 3 actually) & they could run just about 24x7 trying to keep the basement below 50% humidity
one of the newer dehumdifiers I bought has a humidty gauge & I go by that & another one on the other side of the basement
I have a high water table so at times need to run mine quite a bit
Plus I have part of my salt water fish tank in the basement
I used to open the basement door to air out
But a chipmunk ran in one day & was a royal PIA to get him out
Basement humidity should be kept at or below about 65 percent during the summer
Old 09-19-2009, 03:06 PM   #5
The rotten window frames are letting in water wen it rains. Also in a seperate room in the basement theres a well with a sumppump. When i first bought the house the pump was old and didn't work verry well. I had so much condinsation behind the breaker box that I had three breakers weld themselves to the bus bar! so I had a new pannel installed and a new pump. I also have a dehumidifier in the room with the electric pannels. It stay dry for the most part until it rains
Old 09-19-2009, 04:12 PM   #6
First thing to do would be to replace the windows. If there are any other water issues, repair them as well.
Ron
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 10:26 AM
Do I need a vent on a basement utility tub? skipjack Plumbing 7 09-05-2008 06:57 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
Roughed in basement vent question jeffgator Plumbing 5 01-27-2007 11:48 AM
