Basement Support Column Rust - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 10:09 AM   #16
Rewards Points: 5,336
Originally Posted by _alphaBeta_ View Post
Understood.
Out of curiosity, why are the supports rusting that high up though? His explanation made some sense that water is reaching the top of the support on the inside. Certainly no water has reached the outside that high off the floor.
Maybe the pole wasn't properly painted to begin with.
The only way the pole is filling with water, is a water episode from above. That would also be very hard as the pole is usually capped with a solid plate welded to the column.
If the pole was rusting from the inside out, you would be able to put a nail through the hole in the pole.
Just sand the rust on the pole. If you see bare metal underneath, it's rusting from outside the pole.
Ron
B. Franklin 1759
Old 08-19-2011, 09:06 PM   #17
Rewards Points: 558
That is only surface rust my friend. We paint them all the time in the shop with one coat of red oxide primer and when it gets to the site they drag the columns through the mud, dirt leave it out in the rain and snow and scrape it all up even before it get installed with mud still on it.
epson is offline   Reply With Quote
Basement - Removing or moving support post jfgagnon Remodeling 12 08-08-2011 08:11 AM
lally column loosed from basement floor sonofthetonsured Building & Construction 8 06-28-2007 02:24 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
