Basement Stair Support Posts - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-25-2010, 05:38 PM   #1
Rewards Points: 150
Basement stair support posts
I was just looking for some insight to find out if these two posts at the bottom of my stairs are supporting.
I know it all depends, but typically where would they need to be?
alecmcmahon is offline   Reply With Quote
Old 11-25-2010, 09:13 PM   #2
Rewards Points: 1,092
The near one appears to be load bearing, carrying what weight is on (what looks like) that header to the right of it. When you take out a floor joist to insert a stairway, someone has to carry what load that missing floor joist can not. Hence, the header and post. Do you want to move it?
Old 11-25-2010, 09:17 PM   #3
Rewards Points: 150
There is only about 3 feet worth of house in front of the stairs till the brick wall. above this is my front door and entry way, directly above being a closet.
They just look like cheapy 1x4s laminitaed and nailed together.
I'd like to maybe eliminate this to have a more open feel.
some clearer pics
Old 11-26-2010, 12:36 AM   #4
It now appears that the blocking transfers the load from the "missing" floor joists to neighboring, double joists, so I don't see what the posts are really doing. Still, I'd sure get the opinion of a good builder, who can get the whole situation in his/her sights. Let us know what you find out. j
Old 11-26-2010, 10:33 AM   #5
Drywall contractor
Rewards Points: 1,070
There's likely a round, steel column there and someone boxed it in with 1X's for appearance sake....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Need advice on basement support column problem aibrean Building & Construction 9 06-08-2009 05:29 PM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 03:14 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
