Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-07-2012, 02:14 PM   #1
Basement Repair Before Finishing?
I have attached an image of the damage I am speaking, it goes the entire length of the foundation in the front of my house (apprx. 30ft) and wanted to know if this is normal and I should leave it or if this requires attention before finishing my basement. If it requires repair, what cement/concrete should I use for something of this nature? And is it something where I could just replace that front edge assuming there is no further damage?
Thanks in advance,
Keith
callmevo4short is offline   Reply With Quote
Old 07-08-2012, 09:23 AM   #2
Not sure what we are to see, but I don't see damage. There may be some mortar falling off the bottom plate of a pre 50's house, but mortar does not stick to wood well anyhow. I don't really see a problem.
Old 07-08-2012, 11:08 AM   #3
MarginallyQualified
What is damaged?
TarheelTerp is online now   Reply With Quote
Old 07-08-2012, 03:48 PM   #4
Yeah it's the mortar by the sill, it's basically a long crack from one end of the house to the other, you can see it here going from left to right...
Old 07-08-2012, 06:36 PM   #5
A Little Of Everything
Thanks in advance,
Keith
That looks like a normal basement sill to me. I assume you're going to stud in and drywall? You should be fine.
DrHicks is offline   Reply With Quote
Old 07-08-2012, 07:36 PM   #6
Ok I kind of figured that much but just wanted some opinions from the board... And yes I am going stud and drywall with some insulation...
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 04:11 PM
Finishing basement - insulation problem? Gooter Building & Construction 6 08-24-2009 09:23 AM
Wall repair in damp basement klj General Discussion 3 08-17-2009 05:12 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 01:30 PM
