Basement Reno - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 07:33 PM   #1
Rewards Points: 160
Basement Reno
Going to renovate the basement...had a few questions
1) I was going to soundproof the floor joice area...any recommended product?
2) Pink insulation for the outer insulation?
hellothere123 is offline   Reply With Quote
Old 01-04-2011, 02:37 PM   #2
Handyman
Rewards Points: 512
You can fill the joist cavities with a soundproofing insulation like Roxul, then drywall the ceiling with 5/8" drywall. You can also hang the drywall on some resilient channel to reduce vibrations.
Yes, pink insulation R14 for the exterior walls...and don't forget the vapour barrier.
canadaclub is offline   Reply With Quote
Old 01-04-2011, 06:34 PM   #3
Rewards Points: 160
thanks for the input!
Old 01-04-2011, 07:39 PM   #4
Another option is to have expanding foam insulation blown in the walls instead of the R14 Pink. Either will work. Just as important is the vapour barrier / waterproofing. If you have to cut back on costs, DON'T do it on this part. And make sure you put some sill gasket between the floor ands the sills. Water wicks through concrete and wood should never touch the concrete directly.
Good luck!!!!
BigMan926 is offline   Reply With Quote
Definition of a finished basement vs. unfinished hectorlopez Building & Construction 2 01-31-2010 08:31 AM
Housewrap for basement reno mashedthumbs Building & Construction 3 01-23-2010 12:31 AM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 12:21 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
