Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-30-2011, 06:22 PM   #1
basement problem
My basement is going to be waterproofed on the inside. In order to do this the company must cut off the knotty pine wall 2 feet up from the floor. What can I do to fix this 2' of cement block that will be exposed? Above this area will remain the knotty pine walls. I hope someone will understand what I am talking about!!!
banana is offline   Reply With Quote
Old 05-30-2011, 06:54 PM   #2
Super Moderator
basement problem
Welcome.Banana----I'm going to move this into the general forum--You will get more views there.
Old 05-30-2011, 07:01 PM   #3
Super Moderator
basement problem
Banana---I suggest that you get a finish carpenter in there--or do this yourself--
Have the carpenter make the cut--at 28" or 32" --this is the typical height of a chair rail--or wainscot
After the water proofers are complete and the work checks out--
Get the carpenter back to restore the wall using the old pine paneling --with the scar hidden by a new chair rail.----Mike----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
banana (05-31-2011), gregzoll (05-31-2011)
Old 05-31-2011, 09:32 AM   #4
basement problem
Thank you so much! That is an excellent idea. I appreciate you taking the time to help me. Sincerely, Banana
Old 05-31-2011, 10:14 AM   #5
Super Moderator
basement problem
You're welcome---I get these calls occasionally-- I like your screen name--easy to remember--Mike--
Old 06-01-2011, 12:04 AM   #6
basement problem
banana-why are you waterproofing on the inside? are you sure this is the best course of action. sounds to me like you haven't done all of the research.
federer is offline   Reply With Quote
Old 06-01-2011, 08:02 AM   #7
basement problem
If you want to reuse this wood, I'd remove it myself and not leave it up to the contractor.
Ron
mike - Radon problem in basement ggogmo1 Building & Construction 21 06-15-2011 07:21 PM
Basement Shower Problem carolfleming Flooring 1 03-17-2011 08:17 PM
Drainage problem, basement flooding thunderhead Plumbing 1 06-05-2010 09:05 AM
basement floor problem money pit Carpentry 3 11-12-2009 05:17 AM
Is having a sump pump an indication that the basement has a flooding problem? MCK Plumbing 7 08-24-2009 09:57 AM
