Basement Plumbing Closet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-25-2013, 01:29 PM   #1
Framing basement and have a 3'x3' square enclosure that will house my main sanitary sewer lines. This will be framed with an 18" closet door on one side and drywall 2x4 construction on the other three.
Question:
What would be the best course of action to deaden the sound of water passing through these pipes when toilets are flushed upstairs?
My thoughts are....
1. Insulate with normal batt insulation and call it good
2. Drywall the interior of the closet and call it good
2. Insulate and drywall interior and call it good
This closet is right in the middle of the basement and I don't feel like hearing water every time someone takes a shower or flushes a toilet upstairs.
poorboy01 is offline   Reply With Quote
Old 09-25-2013, 02:43 PM   #2
Rewards Points: 378
http://alsnetbiz.com/homeimprovement/faq10b.html
and the internet is full of product suggestions for this purpose
Old 09-25-2013, 03:20 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
If cast iron pipe insulating the walls should do it.
If plastic pipe insulate both. Plastic pipe is noisy
Sent from my iPhone using DIY Forum. Watch out for spell check
Old 09-25-2013, 05:15 PM   #4
Yes it is plastic, when you say insulate both can you please explain.
Old 09-25-2013, 05:37 PM   #5
Plumber
Rewards Points: 348
I guess I misread your post
I would wrap the pipe with insulation and insulate the walls
But at the minimum- insulate the walls
Drywall by itself probably won't help much
Old 09-26-2013, 12:15 PM   #6
Thanks for the information. I think I'll insulate walls first and gauge sound level. If more is needed then I can add pipe insulation (wrap).
As far as wrapping those sewer lines...I've never seen closed cell insulation for 3 and 4 in PVC....special order I guess or is their a blanket type insulation that I should be looking.
Plumbing in basement ithm Plumbing 1 04-10-2013 06:32 AM
What is this pipe in basement closet? zimaad General DIY Discussions 9 11-11-2011 11:40 PM
Could use advice regarding plumbing for a basement bathroom raaczb Plumbing 3 01-22-2011 01:22 PM
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 05:14 PM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 09:30 AM
