Basement Leak. Sump Pump Or French Drain? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 09:48 AM   #1
Rewards Points: 12
Basement leak. Sump pump or French drain?
I live on a sloping property. When it rains heavily a lot of water is flows to the front wall of the houses foundation. I get water in the basement.
I have had a few contractors look at it. If their specialty is basement waterproofing they recommend a sump pump. If their specialty is landscaping and French drains they recommend a French drain.
I would prefer to not cut a hole in the foundation and install a sump pump. Would like to try a French drain first and route the water to the side of the house and down the hill.
Any advice?
Jim
Jmcnyc is offline   Reply With Quote
Old 08-14-2011, 11:08 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
I'd start with prevention first and see if that fixes the problem.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-14-2011, 11:26 AM   #3
Rewards Points: 5,336
Any advice?
Jim
Second Clutch's advice. Stopping or redirecting the water would be the first thing I'd attempt. Perforated pipe, drainage channels or retianing wall might redude or eliminate the water issue.
French drains require a sump pump to get rid of the drain directed water.
Ron
B. Franklin 1759
sump pump crock with no pump or drain installed mauragolf2 Plumbing 5 06-25-2011 09:30 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Do I need seperate vent stacks for basement pump and basement sink? twinfins Plumbing 5 12-08-2010 12:28 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
