Basement Leak - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 09:59 PM   #1
Basement leak
basement is leaking water right under front stoop under front door. I sealed everything from top. Any suggestions
phil
PM1756 is offline   Reply With Quote
Old 05-23-2011, 06:02 AM   #2
DIY staff
Rewards Points: 7,174
We will need a picture of that front step and the damage inside---then you will be able to get solid suggestions.---Mike---
PM1756 (05-24-2011)
Old 07-12-2011, 09:00 PM   #3
Basement leak
LEAKING UNDER FRONT STOOP RIGHT BELOW FRONT DOOR. HELP! KEEP GETTING PIC EXCEEDS 100KB. I DROP DOWN TO ONE PIC!
PHIL
Old 07-12-2011, 10:04 PM   #4
Work Hard, Play Harder
Rewards Points: 212
PHIL
The picture can only be so big; resize it yourself or upload it to a site like imageshack.us that will resize it for you; then you can post it here.
All caps on the internet is still considered yelling. I have water coming into my basement right now; calm down.
Maybe you could describe the problem in more than a sentence?
coderguy is offline   Reply With Quote
The Following User Says Thank You to coderguy For This Useful Post:
jomama45 (07-13-2011)
Old 07-17-2011, 06:00 AM   #5
Thumbs up
Basement leak
thanks! I"ll do that
Old 08-07-2011, 06:22 AM   #6
Old 08-07-2011, 06:46 AM   #7
hope fully i got this right this time regarding basement leak. Any help would be greatly appreciated! profile.imageshack.us/user/pm1756
thanks!
Phil
Old 08-07-2011, 06:52 AM   #8
profile.imageshack.us/user/pm1756 in case insert doesn't work.
thanks!
Phil
Old 08-07-2011, 06:59 AM   #9
the Musigician
DangerMouse's Avatar
How to resize photos to post them here.
might help. Those pics are tiny! Very hard to see what is going on.
DM
Tags
basement leak
Is it leak from the basement or from The Heater? samerhajjaj HVAC 9 11-23-2010 10:13 PM
basement leak KD1 Building & Construction 4 09-24-2010 10:35 PM
Leak in basement from time to time. willowgirl Building & Construction 13 12-30-2009 07:32 AM
How to stop a leak in basement wall? Ammons Home Building & Construction 6 03-04-2009 01:24 PM
Leak into basement at bottom of Door deepstuff Building & Construction 8 08-19-2008 01:46 PM
