Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-05-2012, 12:08 PM   #1
basement heat
Hello have a question I have baseboard heaters in the basement. Problem is even though it heats the room well its actualy chiily from the floor and up about 24 inches stand up its hot sit on the couch chilly is this normal and do you have any suggestions on how to make it better
DJKevin is offline   Reply With Quote
Old 01-05-2012, 12:22 PM   #2
MarginallyQualified
basement heat
Originally Posted by DJKevin View Post
...have baseboard heaters in the basement... heats the room well
...chilly from the floor and up about 24 inches... stand up its hot
...any suggestions on how to make it better
Two suggestions: insulation and circulation.
What is on the floor? On the walls? On the ceiling?
Do you have any fans to try to move the air around?
hth
Old 01-05-2012, 12:35 PM   #3
basement heat
I have carpet on the floor and the walls are insulated I guess I should try a small fan
Old 01-05-2012, 12:45 PM   #4
MarginallyQualified
basement heat
I hate ceiling fans but this is exactly what they are intended for.
As it's a basement... try what I use everywhere:
small oscillating fans on a high shelf do a great job and for cheap money.
hth
Old 01-05-2012, 02:57 PM   #5
basement heat
Thanks I will try the fans
Old 01-05-2012, 03:33 PM   #6
basement heat
This is one of the issues with electric baseboards the air does not circulate as with forced air.
mae-ling is offline   Reply With Quote
Old 01-05-2012, 04:22 PM   #7
basement heat
As per Tarheel, INSULATE, somehow. The more you insulate, the less stratification you'll have.
Old 01-09-2012, 11:39 AM   #8
basement heat
Okay the small fan on a high shelf works great.I just point it downward and the air circulates 100 percent better. Great !!!
Old 01-15-2012, 03:28 AM   #9
Thread killer
basement heat
Do you mean it doesn't circulate in the same manner as scorched air?
Canucker is offline   Reply With Quote
split level, unfinished basement with radiant heat - floor/insulate questions krisbfunk Building & Construction 10 01-16-2011 11:09 PM
Adding heat supplies and cold air returns to basement RAYCC3 HVAC 0 09-14-2009 02:57 AM
Adding heat registers to basement brick1930 HVAC 0 08-24-2009 06:52 PM
radiant heat in basement plgrm HVAC 2 12-09-2007 07:41 AM
basement bathroom heat ktrehs HVAC 3 03-12-2007 04:23 PM
