-   -   basement heat (http://www.diychatroom.com/f2/basement-heat-128899/)
DJKevin 01-05-2012 11:08 AM
basement heat
Hello have a question I have baseboard heaters in the basement. Problem is even though it heats the room well its actualy chiily from the floor and up about 24 inches stand up its hot sit on the couch chilly is this normal and do you have any suggestions on how to make it better
TarheelTerp 01-05-2012 11:22 AM
Originally Posted by DJKevin (Post 813265)
...have baseboard heaters in the basement... heats the room well
...chilly from the floor and up about 24 inches... stand up its hot
...any suggestions on how to make it better
Two suggestions: insulation and circulation.
What is on the floor? On the walls? On the ceiling?
Do you have any fans to try to move the air around?
hth
DJKevin 01-05-2012 11:35 AM
I have carpet on the floor and the walls are insulated I guess I should try a small fan
TarheelTerp 01-05-2012 11:45 AM
I hate ceiling fans but this is exactly what they are intended for.
As it's a basement... try what I use everywhere:
small oscillating fans on a high shelf do a great job and for cheap money.
hth
DJKevin 01-05-2012 01:57 PM
Thanks I will try the fans
mae-ling 01-05-2012 02:33 PM
This is one of the issues with electric baseboards the air does not circulate as with forced air.
jklingel 01-05-2012 03:22 PM
As per Tarheel, INSULATE, somehow. The more you insulate, the less stratification you'll have.
DJKevin 01-09-2012 10:39 AM
Okay the small fan on a high shelf works great.I just point it downward and the air circulates 100 percent better. Great !!!
Canucker 01-15-2012 02:28 AM
Do you mean it doesn't circulate in the same manner as scorched air?
