-   -   basement with garage insulation question (http://www.diychatroom.com/f2/basement-garage-insulation-question-92752/)
WS6transAm 01-18-2011 07:42 PM
Hello.
I have a 1 and a half story house on a full basement which is doubles as a garage. The first 3rd of the basement/ garage ceiling is insulated. -The front part over the garage door. The furnace is in the basement which keeps it around 40-50ish down there, depending how cold it is outside. I live in Binghamton NY. The overhead door is insulated but is colder by it. I park in the garage daily. Most of the basement is underground with the exception of the front wall with the overhead door.
My question is would it worth insulating the other 2/3's of the basement ceiling to save on heating? I found 23" by 8" think insulation that would work. The floor joices are 21" apart inside length and 8" deep. The ducts (forced hot air) are not insulated which helps keep the garage warmer. I do use the basement occasionally for working on my toys and using my bar down there/playing beer pong/partying. Any help would be much appreciated.
gregzoll 01-18-2011 09:50 PM
First question is, is there a wall separating the garage space from the basement? If there is not, then you really can not use the garage to park vehicles or lawn equipment in it. If it does have a wall, then the first thing I would do, is assess how much it costs for Spray foam vs. Roxwool, and how much for 5/8" drywall to be put up & joints taped & mudded. You can follow the info at buildingscience.com per insulating basement/crawl spaces, which would also apply to attached garage space, but keep in mind that the XPS foam board has to be covered with Gypsum to consider it firesafe.
WS6transAm 01-18-2011 10:52 PM
There's no wall barrier. It's a tandem garage so I can fit 2 cars deep in it and I have 3 motorcycles in it now so I'm not really planning on putting up a wall because I wouldn't be able to fit everything in it. I'm just concerned with the insulation on the ceiling right now. Thanks for your input.
gregzoll 01-19-2011 08:46 AM
If there is no dividing wall from the living area (ie basement), I would get that up first with a Fireproof door. Then you can go about with either putting Roxwool on the walls, and Sprayfoam on the Ceiling. As stated before, because there is no separating barrier from living to garage space, it can not be considered a garage.
ferris13 01-20-2011 06:44 PM
2 cents worth - Must seperate HVAC from the garage else your drawing fumes into your home.
gregzoll 01-20-2011 08:03 PM
The OP needs to watch the Holmes Inspection episode, in which a couple had the same item of interest, and brings to light why it is not a wise idea.
Gary in WA 01-20-2011 11:58 PM
Very good points brought out for your safety. Here are a few basic Codes for garages, keeping them separate from living spaces; Page #4, 5/8” drywall on garage ceiling common to house, fire-door, etc.; http://www.codecheck.com/cc/images/CC5thEdSample.pdf
Please contact your local Building Department or Fire Department as these rules are for fire safety. As far as using fiberglass; http://www.diychatroom.com/f98/how-b...ulation-90438/
Get the whole ceiling covered with drywall, at least...........
Gary
WS6transAm 01-21-2011 07:15 PM
Thanks for the information. I bought insulation and 5/8" fireproof drywall today and started doing the ceiling. I've got a lot ways to go.
