Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-26-2011, 03:25 PM   #1
Basement Framing
Quck question,
I am starting to frame a wall (in the basement) but unsure on how far the base plate should be from the wall. Any help?
Mac2011 is offline   Reply With Quote
Old 03-26-2011, 07:42 PM   #2
Super Moderator
Basement Framing
I generally leave 1" to 1 1/2" --That allows for the out of plumb foundations--
Old 03-26-2011, 09:16 PM   #3
firehawkmph's Avatar
Basement Framing
I usually leave 1/2". The basements I finish are generally houses less than 20 years old. Around here if the block is out more than a 1/2", it usually means there is a problem with the foundation.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
oh'mike (03-27-2011)
Old 03-27-2011, 08:09 AM   #4
30 years in construction
canada94's Avatar
Send a message via Skype™ to canada94
Basement Framing
Half inch is plenty, a basement shouldnt be out more than this much.
canada94 is offline   Reply With Quote
The Following User Says Thank You to canada94 For This Useful Post:
Old 03-27-2011, 02:31 PM   #5
Basement Framing
My basement is insulated with R12 foundation wrap, so I built my walls 3 1/2" from the basement walls.
This takes about 8" away from the size of the room.
Old 03-27-2011, 04:17 PM   #6
Basement Framing
Wildie, I count 14" cubic inches from the total area. I vote 1/2" from the walls.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 03-27-2011, 05:08 PM   #7
General Contractor
SeattleSurfaces's Avatar
Basement Framing
Take some plumb readings all around the room. Make sure if any of your walls are out that you adjust your measurement so you can carry your gap up with the wall still plumb.
Sucks to start framing and find a wall out of plumb by more than your 1/2".
Also depends on what you plan on doing for insulation.
SeattleSurfaces is offline   Reply With Quote
Old 03-27-2011, 05:42 PM   #8
Experienced
Jackofall1's Avatar
Basement Framing
You have all mentioned "Plum" but what about straight.
Should we not mention the straightness of the wall, or are we going to assume it is straight, you might as well figure where the wall is at its worse for "plum" also run a string line on its length about an inch or so away from wall, to map out where the most abrupt point of the wall(s) are.
Mark
Old 03-27-2011, 09:33 PM   #9
Basement Framing
Lets start all over again, as I'm not following you?
Did I make a mention of area somewhere?
Old 03-27-2011, 10:37 PM   #10
Basement Framing
You said,
I assume your taking about 3 1/2 inches from each wall, 3.5" x 4 walls = 14 square inches
Not to mention each wall is about 4" thick, so you loose approximative 2' 6" from the total area.
Not trying to be a , its just the OP will want to take this into account when building away from the foundation walls.
Old 03-28-2011, 10:25 AM   #11
Basement Framing
You said, I assume your taking about 3 1/2 inches from each wall, 3.5" x 4 walls = 14 square inches
Oh, now I understand! I meant to say that it takes away about 8" from each outside wall.
Of course, any framing will encroach into the room space, so in my case I would have lost 4", anyway if I had framed tight to the wall. However, I lost another 4". The net result was 8" per outside wall.
Old 03-28-2011, 11:55 AM   #12
Basement Framing
That air gap between the foundation and your framed wall is important. The gap allows air flow and will help if any moisture penetrate thought the foundation. You will never notice 1/2 inch to 2" gap when all is said and done. Plumb is most important, but it doesn't hurt to pull some string lines to make sure the wall is straight. When I finish a basement I build my walls 3/4" short and actually use 3/8" bolt and aluminum plates to jack the bottom plate off the cement floor. This way you have no wood touching cement and allows for air flow which aids in a dry basement. Also using a piece of composite 2x4's for the bottom plate will save it from rotting when you get water in your basement.
Ok, I am ready for how overkill this is and all the naysayer that will comment, but I always go the extra mile. Seems to payoff in the long run.
screwy is offline   Reply With Quote
Old 03-28-2011, 01:02 PM   #13
Basement Framing
I used 1X4 PT blocks on 2 foot centers to raise the plate off the floor. For the laminate flooring I used DELTA dimpled underlay underneath to allow airflow under the floor also!
i have also installed 2 bathroom fans, mounted in the walls to pressurize the envelope and to generate air flow behind the walls and under the floor.
Old 03-30-2011, 10:25 PM   #14
Moderator
Basement Framing
If going for a finished basement, don't leave air gaps for convective loops or moisture from the basement air condensing on the colder concrete wall; http://joneakes.com/jons-fixit-database/743
http://www.swinter.com/services/docu...Insulation.pdf
http://www.buildingscience.com/docum...ent-insulation
http://www.buildingscience.com/docum...lation-systems
You want to prevent any basement air from reaching the wall, starting with ADA; http://www.buildingscience.com/docum...wall-approach/
Gary
Clothes taking longer to dry?
Insulate split framed/poured basement wall, prior to framing... pasichnyk Building & Construction 9 12-20-2010 06:32 PM
framing basement walls nickm1024cobra Remodeling 1 11-08-2010 01:06 AM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Suggestion for framing around ducts/pipe in basement xuc318 Building & Construction 2 12-19-2009 07:07 AM
Framing basement wall without covering top plate and rim joist dave11 Building & Construction 5 10-30-2009 09:38 PM
