Basement Framed - Please Help. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-25-2009, 11:33 AM   #1
Basement framed - please help.
I recently removed the old paneling that surrounded my basement walls. The walls have 2x4's nailed directly to them and it does not look like the walls are sealed.
I am wanting to drywall the surroundings, but want to know what steps I should take to install some sort of insullation.
I live in Michigan and the walls are currently framed only - nailed to the cement basement walls.
All forums show how to vapor barrier before framing, but I am beyond that stage.
Do I 6mil water vapor over the 2x4s, mount pink Rigid Foam, then drywall? Please help with any suggestions or comments as I want to wrap this project up correctly.
itlnStln is offline   Reply With Quote
Old 08-25-2009, 11:59 AM   #2
Registered User
Termite's Avatar
You don't want your wood material on the exterior side of a vapor barrier. In my opinion you'd be better off without a vapor barrier unless you're willing to take the framing down and re-do it.
Are there moisture/humidity issues in the basement?
Old 08-25-2009, 12:01 PM   #3
no moisture, but has standard "basement humidity".
Old 08-26-2009, 12:12 AM   #4
Registered User
Rewards Points: 4,944
http://www.buildingscience.com/docum...hterm=basement
Foam,1", glued to concrete below grade. Framed wall on p.t. plate on sill sealer or tarpaper. Seal all joints with tape, unfaced insulation at wood wall, drywall, texture, paint with latex to allow assembly to dry to inside. Use Dens-shield, way better. No vapor barrier, as Kc said. Be safe, G
Old 08-29-2009, 10:50 PM   #5
Rewards Points: 156
If going with the 1-2" of foam on foundation wall then frame a wall and use unfaced insulation do you build the framed wall right up against the foam to help hold it against the foundation wall or do you leave some sort of space between the foam and the framing?
If going the way of using furring strips directly over the foam how do you handle any plumbing on the wall say for washing machine and drop sink supplies when the gypsum board will mount right to the furring strips?
And last, what type of drywall material is recommended to use in a basement setting?
Thanks for the links this may be my winter project this year
creamaster is offline   Reply With Quote
Old 08-30-2009, 12:29 AM   #6
Registered User
1" air space to foam from framing as per article. 1" of foam, otherwise the foam stops the moisture from drying to the inside room.
Need to frame wall out to include pipes.
If no outside drain-tile with waterproofed exterior wall below grade, expect some moisture to get through. Base drywall material on past history of concrete wall's wetness. Gypsum board, special gypsum board, Dens-shield, etc.
http://www.rd.com/57548/article57548.html
http://www.buildingscience.com/docum...ent-insulation
Be safe, G
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
