Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-25-2009, 12:13 AM   #1
Basement flooring options
We have a 250 square foot basement that we are finishing. there is a drain (and hose that goes to the drain ) for the air conditioner. It is in the front/center of the room. We are planing on painting the floor. Are there any other options to our drain situation?
someone mentioned cutting the concrete and putting the hose in a notch in the floor. i cant imagine that would be a good idea.
CooperChloe is offline   Reply With Quote
Old 01-25-2009, 02:12 AM   #2
Can you not redirect the drain hose from the air condition to drain it's water onto your lawn/property somewhere instead of into your basement catch basin?
I'm gonna presume you've already thought of that, so perhaps you could explain why doing that isn't feasible in your case, and we can direct our attention to solving THAT problem.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 01-25-2009, 05:23 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
On one renovation we had to install an air handler in the basement to supply the first floor of the house, we then install a small pump on the floor next to the unit the pump had a small basin which had a float switch inside that turned the pump on when the water level reached a pre set height. then we hard piped it with, I believe a 3/8" copper line out through the foundation and onto the drive way along side the house. i,ll see if I can locate it and post it for you. BOB
Old 01-25-2009, 05:30 AM   #4
buletbob's Avatar
Here you go!!
LIttle Giant 115V Condensate Removal Pump
Specials, Condensate Pumps
Quantity in Basket: none
Code: CONDPUMP01
Price: $74.29
Flooring for basement with water issues Leoskee Flooring 27 08-27-2008 09:49 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 02:04 PM
flooring for a lousy basement floor? johnny331 Remodeling 5 06-06-2007 07:04 AM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 10:08 AM
