Basement Egress Requirement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 09:15 PM   #1
Question
Hi All,
Hopefully someone out there can help answer my question. I am in the process of looking for a townhouse in south east Pennsylvania. A lot of the homes I have looked at have finished basements, but none have been walk-outs or have egress windows. As an example, one house built in the late 80s had the basement finished in 2006, would the owners have been required to put in a form of egress to be up to code? If I buy, am I going to be responsible to add an egress window at some point? If anyone out there can help to explain basement egress requirements to me that would be fantastic. Thanks in advance for your input.
nickb is offline   Reply With Quote
Old 02-11-2013, 09:30 PM   #2
Rewards Points: 14,026
Really need to be asking these questions down at your local building dept.
Requirements differ from area to area.
Highly unlikly there going to make you go back and add one now unless all this work was done without permits.
Old 02-11-2013, 09:34 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by nickb View Post
...but none have been walk-outs or have egress windows.
Have any of these had bedrooms downstairs?
Old 02-11-2013, 09:36 PM   #4
None have had bedrooms in the basement.
Old 02-11-2013, 09:40 PM   #5
If there's a closit down there they may now concider it a bedroom.
Old 02-11-2013, 10:00 PM   #6
MarginallyQualified
iirc... an egress windows (20x24 min?) was only required in bedroom spaces until a few years ago. Now, any finished basement must have at least one.
Old 02-11-2013, 10:10 PM   #7
Rewards Points: 6,652
Our city considers that as long as you do not plan on using it as a sleeping area, you can get away without having to put one in. The majority of the places in my town, that are built before the whole Egress window thing took off, are grandfathered in, with even quite a few that did do sleeping areas under the radar, with no permits, but everything up to code (mechanical's, electrical, plumbing).
I know of one in particular that was just recently remodeled in the past three years, no permits, up to code, no egress, due to considered not really there, because the city does not know. Even if someone did go to our city, they would just say as long as the work was properly done, they do not care about it being finished.
Old 02-12-2013, 09:54 PM   #8
Pro
Rewards Points: 91
I'll just refer to the part about whether you will be "responsible to add an egress window" at some point. As an owner, you're to some extent responsible for the safety of the people in your home, and if you knowingly exposed them to some risk, well yes, you'd bear some responsibility of something actually went wrong.
That's not what you mean, I think. You're asking, will the city force you to make expensive changes to your house? Well, building departments don't have the resources to run around just looking for problems. What prompts a notice of violation is generally one of several events - a new building permit for work in the code-violating area, a complaint (a neighbor who dislikes you tells the city you've just added a bedroom to your basement), a fire or an insurance claim caused by the out-of-code part of the home. On its own, the city won't show up and ask you to fix your basement. If they did, you'd also have the option simply to "unfinish" the basement.
If the work was permitted and to code at the time it was done, it's still legal. 2006 is pretty recent, of course.
CarpenterSFO is offline   Reply With Quote
Old 02-12-2013, 11:51 PM   #9
747
registered
747's Avatar
Rewards Points: 534
It depends on your municipality. Some can require several windows depending on square footage. Others may not. They also look at what its going to be used for. Example apartment would require more escape then just a hangout room in your house.
747 is offline   Reply With Quote
Tags
code , egress , finish basement
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
