Basement Construction - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 10:51 PM   #1
Have a question, finishing my walkout basement and don't want to spend money on drywall and heard about wood plank walls, are these good to use and inexpensive or a waste of time?
Curtsingers23 is offline   Reply With Quote
Old 12-26-2013, 11:10 PM   #2
Rewards Points: 13,458
Far more costly. Drywalls cheap.
Not a great idea in a basement due to possible moisture damage.
Old 12-26-2013, 11:10 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
I wouldn't skimp here. Insulate and drywall will look and perform better.
Old 12-27-2013, 06:07 AM   #4
DIY staff
Rewards Points: 7,174
For fire stop and draft stopping,you need the drywall---so that would go behind the planks anyway----decide on the look you want---
drywall, or drywall with planks over it----
Old 12-27-2013, 07:31 AM   #5
Rewards Points: 5,974
You really can't get much cheaper than drywall if you are capable of finishing it yourself. And a basement is a good place to learn.
The Following User Says Thank You to ToolSeeker For This Useful Post:
oh'mike (12-27-2013)
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Basement Construction Jamie_K Carpentry 4 03-31-2009 03:22 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
