Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-27-2011, 07:21 PM   #1
basement cinder block leaks
Hi everyone.
I have some small leaks - small pool around drain, not pouring in. These are coming in, in a basement addition, which is a cinder block foundation.
I have identified where the water is coming in and gone and got some hydraulic cement...but wanted some of your opinions.
With it being cinder block and not a poured foundation, Will this just be a bandage?
Reason i ask is the surrounding area outside is 4-6 inch poured concrete, so its not like its as simple as digging up some soil and doing the work outside.
My thought was, use the hydraulic cement from the interior and then re-work a section of eaves trough above as its not the best drainage around the back of the house, where Im having the problem. Obviously that is key here too.
Any thoughts would be greatly appreciated.
iwannabeer is offline   Reply With Quote
Old 10-14-2011, 01:08 PM   #2
Originally Posted by iwannabeer View Post
Hi everyone.
Hi-- Did you fix the water problem ? I have the same leak and was thinking about using the Dry track system -no diging just epoxy to floor to a pump. please let me know how you fixed it -Thanks Marty
martyd40 is offline   Reply With Quote
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 08:48 AM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Leak in the cinder block foundation. 68MHJCs Building & Construction 7 01-25-2008 10:37 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Basement leaks in brick wall Nick General Discussion 8 07-18-2006 05:29 PM
