-   -   basement cinder block leaks (http://www.diychatroom.com/f2/basement-cinder-block-leaks-118509/)
iwannabeer 09-27-2011 06:21 PM
Hi everyone.
I have some small leaks - small pool around drain, not pouring in. These are coming in, in a basement addition, which is a cinder block foundation.
I have identified where the water is coming in and gone and got some hydraulic cement...but wanted some of your opinions.
With it being cinder block and not a poured foundation, Will this just be a bandage?
Reason i ask is the surrounding area outside is 4-6 inch poured concrete, so its not like its as simple as digging up some soil and doing the work outside.
My thought was, use the hydraulic cement from the interior and then re-work a section of eaves trough above as its not the best drainage around the back of the house, where Im having the problem. Obviously that is key here too.
Any thoughts would be greatly appreciated.
martyd40 10-14-2011 12:08 PM
Did you fix ?
Originally Posted by iwannabeer (Post 737173)
Hi everyone.
Hi-- Did you fix the water problem ? I have the same leak and was thinking about using the Dry track system -no diging just epoxy to floor to a pump. please let me know how you fixed it -Thanks Marty
