Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-26-2008, 11:21 AM   #1
Basement
seeing and feeling that I have moisture in the basement I ave installed a dehumidifier and a fan. Just wondering if I could open the metal cellar windows to achieve the same affect.
City68
city68 is offline   Reply With Quote
Old 07-26-2008, 11:36 AM   #2
ccarlisle's Avatar
Smile
Yes; areas of high humidity will always tend to flow to areas of low humidity, so do so if it drier outside than inside. Fans are good too, to help that along.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-29-2008, 01:10 PM   #3
but don't forget to check your weather and see what the humidity percentile is before doing so..
moisture settles low so it'll get through those open windows if it's too humid.
hope your ordeal get's its solution.
Last edited by AtlanticWBConst.; 08-01-2008 at 06:26 PM. Reason: Site Rules Violation: Advertising Link Removed from signature
jking09 is offline   Reply With Quote
Old 07-29-2008, 01:39 PM   #4
basement
Thanks for the advice,,I am in the process of taking out my windows in the basement that are metal, I am cleaning and painting them ,,,Its a moist cellar I have a dehumidifier and a fan to push the moist are out of the basement but perfection is what I am after,,,,
Old 07-29-2008, 05:46 PM   #5
Rewards Points: 6,652
If it is your home, you can do anything you want, but remember the outcome. If you open basement windows, critters can get inside, and if it rains, then you have a different kind of moisture to deal with, along with dust & debris.
Basement mhughrob Remodeling 1 07-11-2008 07:11 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
