Baseboards Separating From Wall In Stairs - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-21-2013, 03:09 PM   #1
Baseboards separating from wall in stairs
My house is about 5 years old. The baseboards in my stairway leading to the 2nd floor are starting to crack/separate. I was thinking of cleaning out the crack of paint and dirt. And then filling the space with some wood filler. Re-caulking and then painting. Does this make since??
Baseboards separating from wall in stairs-024.jpg   Baseboards separating from wall in stairs-027.jpg
Kailyne is offline   Reply With Quote
Old 12-21-2013, 03:47 PM   #2
747
registered
747's Avatar
Rewards Points: 534
Its a movement problem. Easiest fix get some white caulk. Just fill it in really good. Now come behind with a damp washrag with one finger in it. Push and swipe. Clean as a whistle.
747 is offline   Reply With Quote
Old 12-21-2013, 03:48 PM   #3
Rewards Points: 13,300
Not really.
Something's flexing to make it crack like that.
No idea why that thick of a skirt board was used.
It should have been just 3/4 thick material, that looks like it's far thicker then that and it's pulling out away from the wall for some reason.
It should have been tight to the sheetrock.
Wood filler is the last thing you want to use, it's to hard and nonflexible.
There's most likely a reason someone used baseboard and 1/4 round on top of a skirt board like that. Most often just base cap moulding is done.
I'd be cutting the paint line and removing that 1/4 rd. to try and see what's going on.
It's going to need at least some screws into the walls studs to pull it tight to the wall.
Old 12-21-2013, 03:54 PM   #4
747
registered
747's Avatar
Rewards Points: 534
Originally Posted by joecaption View Post
Not really.
I assumed he didn't want to do all this. This would be a permanent solution.
Old 12-21-2013, 04:06 PM   #5
Hammer it to fit paint it to match.
The stringer on my stairs is pulling away from the wall/ studs. georgiabiker Carpentry 10 01-24-2013 04:53 PM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Building stairs next to railroad tie wall sliderule Carpentry 4 06-11-2009 08:54 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
