Baseboard Or Quarter Round For Laminate Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 06:22 PM   #1
sweaty
Rewards Points: 276
Baseboard or Quarter Round for Laminate Floor
I am going to put in a laminate floor on my main level. I would like to replace our old baseboards. Do I also need quarter round? Is it often installed without it?
sweaty is offline   Reply With Quote
Old 08-02-2011, 06:26 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't need Q-round if you are replacing all of the baseboard.
XXX
Old 08-02-2011, 06:29 PM   #3
Old School
Willie T's Avatar
Floors roller-coaster up and down along each wall. Baseboard bends a little in that same plane, but not much. Quarter-round, or 'shoe molding' is much more flexible and follows the floor better.
For aesthetics, they both really should be installed together if the floor is not all that flat.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
oh'mike (08-03-2011)
Old 08-02-2011, 07:05 PM   #4
remodeling pro
In addition, the thickness of the new baseboard alone may not be enough to cover the required expansion gap along the new floor's perimeter; considering that much "production run" quality base is only 9/16" thick and most flooring seems to spec 1/2" expansion gap.
troubleseeker is offline   Reply With Quote
Old 08-02-2011, 07:09 PM   #5
Learning by Doing
Leah Frances's Avatar
In My Opinion - Quarter round looks terrible and cheap.
Use some shoe molding that matches your baseboard. It will look fabulous.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-02-2011, 07:12 PM   #6
Rewards Points: 150
My flooring guy caulks along the bottom of the baseboards and it looks really nice.
Broughton is offline   Reply With Quote
Old 08-02-2011, 08:35 PM   #7
I used cove molding. Much better looking than quarter round, imho.
I wouldn't use the baseboard to cover the edges... baseboard should last a lot longer than the floor will. The molding can come out the next time the floor gets replaced.
almostnormal is offline   Reply With Quote
Old 08-03-2011, 04:43 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 150
I always thought it was the same thing?
Old 08-03-2011, 08:22 AM   #9
DIY staff
Rewards Points: 7,174
1/4 round is as tall as it is wide---3/4"x3/4" for example--
Shoe (or toe) molding is taller than it is wide--3/4" x 1/2" is a popular size.
chrisn (08-03-2011)
Old 08-03-2011, 04:22 PM   #10
Drywall contractor
Rewards Points: 1,070
I prefer shoe to quarter round. It's rare to have a floor flat enough to get by without more than just base, but if yours is and you can cover the "expansion" gap with jut base, go for it....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-03-2011, 05:15 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are you sure about that? I don't know, but that was never the case when I was installing the crap.
A half inch on both sides of a room is enormous and certainly not at all necessary. What a bunch of jumk that laminate has become if that's the case.
XXX
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
Quarter round on round outside corners biyoba Flooring 4 01-07-2007 08:39 PM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 09:30 PM
Quarter round and baseboard justtired Flooring 1 09-30-2006 05:39 PM
