Baseboard Gaps - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 04:28 PM   #1
baseboard gaps
I just put baseboard trim down in my basement and there area few spots where there are small gaps especially where the two boards are butted up and in some spots along the top of the board where the wall meets the board. My question is what is the best way to fill these small gaps before repainting. Also in some spots there is no way to secure the board to the wall due to no stud, is liquid nail a good option in these spots or just caulk it. Thanx
mort5029 is offline   Reply With Quote
Old 04-30-2011, 04:33 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Caulk the gaps. But, most caulks are not adhesives so don't expect the caulk to hold as an adhesive. There are however "adhesive caulks" available that would probably serve both purposes.
XXX
Old 04-30-2011, 05:40 PM   #3
Old School
Willie T's Avatar
This is a great caulk for your purpose. http://www.polyseamseal.com/allpurpose.shtml Available at HD and Lowes.
Willie T
Old 04-30-2011, 10:47 PM   #4
Rewards Points: 5,336
The gaps at the floor are taken care of with a small molding called a shoe molding(around here) or you can use a 1/4 round or a variety of others. They bend more readily then the main base and will conform to the undulations of the floor,
Ron
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
