Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-10-2010, 09:27 PM   #1
Base Moulding Question
What is the best way to handle a butt joint in base moulding? 45 both pieces and overlap or just butt one piece against the next?
Also, how much gap should I leave? We are putting in a thick freesia and 1/2" looks to be about right with the test pieces I've tacked up.
diykc is offline   Reply With Quote
Old 01-10-2010, 09:55 PM   #2
jlhaslip's Avatar
Depends on the profile of the base mouldings. Some of them are difficult to cope cut.
45 miter cuts should work, although on some corners, you may need to cut 44 or 46 degree angles to get a good fit. Or something in between.
jlhaslip is offline   Reply With Quote
Old 01-10-2010, 10:25 PM   #3
Thanks JL, what I'm asking is where I have a long run and have to splice pieces together, is it better to 45 each end or just butt them together. I have 4 long runs like this.
Old 01-10-2010, 10:46 PM   #4
jlhaslip's Avatar
Scarf joints are usually cut in joining pieces mid-span.
Cut them at 22 1/2 or 30 degrees, stain/paint the ends in case of shrinkage. Nail both pieces near the joint.
Best way is to nail the first piece hard. Cut and nail the joint and work the nailing to the far end.
*edit*
A scarf joint is a matching angled cut on two pieces that join in the middle.
The angle is not critical as long as the matching pieces get the same cut.
Old 01-11-2010, 10:49 AM   #5
Drywall contractor
I generally 45 and glue them to keep from separating....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-11-2010, 12:01 PM   #6
Jack of all - master none
hyunelan2's Avatar
I scarf the joint at 45*, and typically put a trim-nail right through both pieces, into the wall, at the joint (if it is not delicate molding that may crack/splinter). Since I use white trim, a quick fill with latex caulk, and touch-up with the same white paint I used for the trim makes the joints virtually disappear.
hyunelan2 is offline   Reply With Quote
Old 01-11-2010, 10:02 PM   #7
The caulking mentioned above is the key. Most joints are just painted over but with a little caulking smeared into the space you have to look really hard to find the joint after you have painted it.
Helmet is offline   Reply With Quote
Old 01-13-2010, 10:01 AM   #8
Thank you! I like it. I nailed closed to each end but I like the idea of pinning them together at the joint and caulk was already in the plans!!
Old 01-13-2010, 10:09 AM   #9
General Contractor
A scarf joint is typically used in production grade trim jobs. Forty-five degrees is typical, reinforced with glue. If done correctly caulk is not necessary but a light sanding of the joint may be. The "best way" to join the two lengths is by doweling them together essentially making one reinforced full length piece. This is usually specified in "high end" trim applications.
ARI001 is offline   Reply With Quote
Crown Moulding Question lda130 Carpentry 2 11-21-2009 11:41 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-15-2007 12:12 AM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 09:29 AM
