Base Cabinet Install On Uneven Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 12:58 PM   #1
Custom User Title
Rewards Points: 252
Base cabinet install on uneven floor
I bought some bathroom vanity base cabinets off of craigslist for a steal. I plan on using them in the basement to create a counter for the laundry room. The floor is poured concrete and the walls are block. The problem is, their used to be a drain in the area and the original owner of the house had it filled in so the floor isn't even/level. What would be the best way to install these. Should I just shim them so they are level and just fasten them to the block. Technically, I probably don't even need to fasten this to anything since its not a finished space but I still need to get them mostly level.
Thoughts?
no1hustler is offline   Reply With Quote
Old 10-07-2010, 01:06 PM   #2
is the floor uneven under the cabinet from front to back, or side to side. Or both...
for what you are doing with them, i would buy some furniture leveling feet at home depot. put them on all four corners of each base cabinet, and you will be able to level them pretty well (unless the floor is WAY off.)
1910NE is offline   Reply With Quote
Old 10-07-2010, 01:26 PM   #3
Custom User Title
Rewards Points: 252
I'd say its probably front to back and side to side. Not more than 1.5-2" though. I like the idea of the floor leveling feet!
Old 10-07-2010, 01:28 PM   #4
Rewards Points: 120
Leveling feet should work fine for what you want to do, but just to provide a couple more options, assuming the floor is probably highest at the wall, you could set it in place, shim it level, then use a compass to scribe the variances in the floor to the cabinet, and cut the base to fit. Or, since that may make it too low, you could shim it level, and nail a 1x4, or other appropriately sized basboard to the perimeter, for it to set on.
Old 10-13-2010, 02:52 PM   #5
Cabinet base for uneven floor
Hey there are many options to level the cabinet that range from leveling the floor first to shimming the cabinet. I found an article here that covers a whole kitchen cabinet install.., and they did cover leveling the cabinet the right way. http://thediyhomepro.com/a00017.php Good Luck
joeys509 is offline   Reply With Quote
a few laminate floor install questions mcvane Flooring 5 11-21-2014 01:34 PM
Installing vinyl plank over existing, uneven floor? AKCDIY Flooring 5 11-01-2014 04:48 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Outlet install in Cabinet? jamiedolan Electrical 5 09-28-2008 01:35 AM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 10:16 PM
