Barn Window Glass Cleaner - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 12:19 AM   #1
Rewards Points: 372
Barn window glass cleaner
I have three windows from a barn that was built in 1889. Each window is divided into 6 panes of glass. They're not leaded glass.
I've cleaned each pane with Windex 2 times and hydrogen peroxide 2 times. That helped a lot, but there was still a haze. Tonight I tried rubbing alcohol and that made it much better. But they're still not completely clear.
Any suggestions as to what I could use to get the glass looking shiney?
gma2rjc is offline   Reply With Quote
Old 08-02-2009, 09:04 AM   #2
Rewards Points: 6,652
Scrub with Bon ami cleanser, then wipe clean with clean paper towels, changing out while wiping. From there, it should be clean enough to shine.
Old 08-02-2009, 09:08 AM   #3
Household Handyman
Rewards Points: 1,408
First, are you sure there are six panes of glass, and not just one large pane with the wooden (memory fart here--what are they called) built onto them? Look at the glass from one side to see if it seems to have "waves" in the pane(s). A lot of glass back then was not made with fancy machinery as we have today, it was poured onto a granite slab. This method gave the glass panes the wavy look. Some of this type glass is just impossible to get that stubborn glaze off of. I have repaired windows in old homes where the homeowner and I agreed that the glass was not to be damaged at all. They like the old wavy glass. But, most of these I've seen were the one large pane per sash. Thanks, David
Old 08-02-2009, 12:14 PM   #4
Rewards Points: 372
That's interesting. Is that the glass that has the air bubbles in it? The house I grew up in had windows like that.
These windows have separate panes. The glass is the same as what you would buy in a hardware store today. I'm assuming that between 1889 and the time the barn was torn down, each pane has been replaced. But maybe not.
In one of the pics, you can see the haze. The glass was built into these windows on a slant.
Barn window glass cleaner-dsc01372.jpg-re-sized.jpg   Barn window glass cleaner-dsc01388.jpg-re-sized.jpg
Old 08-02-2009, 06:41 PM   #5
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Not sure how it will work on glass, but Simple Green works pretty good in the kitchen, bathroom, work shop and for cleaning the oil/sludge/and-whos-knows-what-else off the machines at work.
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 08-02-2009, 07:08 PM   #6
Household Handyman
gma2jrc-Thanks for the pictures, I learn from this forum every day and now I've learned something for today. I've worked on a lot of different windows but have never seen those type. Man guesses as to why they were designed that way. Good Luck on the cleaning process, David
Old 08-02-2009, 07:23 PM   #7
Rewards Points: 372
This morning I soaked a cloth in vinegar and let it sit on the glass for a while. It seems like that would have worked. It didn't.
I'll try the Simple Green. Thanks.
Old 08-02-2009, 08:07 PM   #8
Rewards Points: 372
Thanks Thurman.
This is the first time I've ever seen windows like that as well.
I wondered if the glass was angled that way to direct the rain away.
Old 08-02-2009, 10:50 PM   #9
Rewards Points: 372
This window has this little star hanging in it. I didn't notice it until I started cleaning the cobwebs, dirt and straw away.
Old 08-03-2009, 11:35 AM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
If normal glass cleaning products don't work you may have "sick glass"
I collect old oil lamps and have seen this many times in antique glass items.
This may help explain, or google "sick glass repair":
http://glass-studios.net/sick.html
Old 08-03-2009, 11:57 AM   #11
Rewards Points: 372
Very interesting. That's the first I've heard of that, thanks for the link.
Old 08-04-2009, 11:53 AM   #12
Rewards Points: 562
Best glass cleaner I have used is the Napa window cleaner. Dont know why but it foams ad cleans better than other product AND it stays cleaner longer for some reason
4just1don is offline   Reply With Quote
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 11:57 AM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Double-paned window glass replacement maximizer Building & Construction 5 08-18-2008 01:06 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
